Originally Posted by smart fortimo
"The only sealed system on the market" - smart madness web page.
Define "sealed"...
If you look carefully at other similar products on the marketplace you will see a difference in the way the shield is designed. The shield on the SILA intake has only one opening. In the front where the side vent blows air directly in to the shield and in to the filter.
Other intakes on the market have openings on the back and some also on the underneath. This can allow more hot/dirty air from the engine bay to enter the shield and be sucked in to the air filter. With the SILA those changes are greatly reduced.
In addition, the SILA Aluminum intake is much lighter that the other intakes on the market.
Hope that helps explain it a bit better. If you close examine the pictures of all the intakes and the shields you will see a difference. All of them are good products, but we believe the current SILA intake is one of the best solutions in the marketplace.
