Smart Madness now offers Cruise Control - Smart Car of America Forums : Smart Car Forum
Go Back   Smart Car of America Forums : Smart Car Forum > Marketplace > Vendor Marketplace
Trailer
Old 02-05-2009, 01:33 PM   #1 (permalink)
Supporting Vendor
SmartMadness's Avatar
For those that are interested in a cruise control....
We now have units in stock and ready for delivery. This cruise control comes from Germany, is an easy install and is the identical unit that the EU smart dealers install on their smarts. Here is the direct product link:
Smart Madness - Smart Car Parts and Accessories
Thank you!
__________________
Old 02-05-2009, 01:43 PM   #2 (permalink)
jwarner6's Avatar
Looks nice and I certainly like the price. But I'm going to have to see a whole lot more related to installation and compatibility before I seriously start to consider it over the 451 unit. For starters, how about compatibility with the intermittent wipers?Thanks.Jeff
jwarner6 is offline   Reply With Quote
Old 02-05-2009, 03:14 PM   #3 (permalink)
sheureka's Avatar
Does this cruise work in both auto and manual modes? TIA - sheureka
Old 02-05-2009, 04:15 PM   #4 (permalink)
This is the Mr. DotCom unit that used to be the only unit until Area 451 finally came out with their own. This is a great price for the unit, down almost $50 from what I paid for mine 6 months ago at SmartieParts, which now only sells the Area 451 unit. The change on Steve's part (per my e-mail with him last month) was because MDC has given him grief over replacement units in the recent past. Though I do susspect the fact that he now owns controlling interest in Area 451 may have had something to do with the change too.
As for wanting more installs, there are literally thousands of MDC units installed in the US, Canada, and Europe, since again, they were the ONLY option on most smart models. The Area 451 is the new-comer to this party, not the MDC. The stalk is an actual smart part (for the roadster I believe), and looks stock in the car. There's a VERY slight tint difference which you will only notice if you hold the old one up next to it for comparison.
The MDC unit has a few differences vs. the Area 451. First off the MDC unit is installed completely in the front dash area. The longest wire is about 3', from the accelerometer to the PCB in the dash. The hook-up is MUCH simpler with only 2 pass-though plugs, one for the gas pedal and one for the accelerometer.
Feature wise, the MDC unit offers cruise (with up/down hit on the stalk), a settable governor , and an operational lock feature. The cruise and governor work on the same principal, so only one can be engaged at a time. The lock feature sets a 4-button sequence that must be entered on the stalk to unlock the car (in addition to the key, etc).
The only advantage that the Area 451 has (IMHO) is that it senses a little more about the car systems. The MDC unit only works in Drive mode, not in manual mode like the Area 451. And while the MDC unit shuts off on breaking, it doesn't detect and disable on ESP or traction control turning on like the Area 451 unit does.
I've been using the MDC unit for over 6 months now, and love it. It's a great little product, took about 2 hours to install, and could be removed or re-installed in under 20 minutes (now that I know how it all works ). At the price they're charging now, it's a great deal!
Old 02-05-2009, 07:49 PM   #5 (permalink)
sheureka's Avatar
I've been using the 451 unit for over 6 months now, and love it. It's a great little product, took about 2 hours to install, and could be removed or re-installed in under 20 minutes (now that I know how it all works ). At the price they're charging now, it's a great deal!
Okay, I'm confused - are you using the MDC unit or the Area451 unit? - sheureka
Old 02-09-2009, 07:43 PM   #6 (permalink)
My bad... I'm using the MDC unit. I was doing so much comparison between the two that I typed the wrong one in that sentence. I do have to say, both look like good options. I just like the MDC one because it was out more than a year before the Area 451, has more real-world testing, and has a few more features. At this price... the MDC is the clear winner.
Old 02-09-2009, 08:21 PM   #7 (permalink)
It works fine with all the other features. The MDC install is far less intrusive, since all it really does is emulate the gas pedal. The tap into the accelerometer from what I read is just to get access to the data bus, which tells it the current speed, brake status, and drive mode. The only output is to the gas control line, where it's pretending to be the pedal. It doesn't try to change the shifting pattern or affect any other system. And,it doesn't require re-wiring a harnes block that you have to re-wire again if you decide to remove it later.
I have a cabrio with the options package, and can tell you all the options work just like they did before the install, including the auto-wipers setting. The replacement stalk has all the same movement/trigger options as my cabrio stock stalk. It just has 3 more options now; the end cap is an enable button for the cruise, and the up-down flicker for adjusting speed.
Old 02-10-2009, 10:38 AM   #8 (permalink)
jwarner6's Avatar
Awesome! Now I just have to go start digging in the back yard to find some money.
Thanks.
Jeff
Old 02-14-2009, 09:42 PM   #9 (permalink)
For those of us without any technical expertise, what type of a place would you suggest turning to to install this?
Thanks,
Gar
Gar Blume is offline   Reply With Quote
Old 02-14-2009, 09:59 PM   #10 (permalink)
chasingrabbits's Avatar
Woody, thank you so much for the informative write up. I have been looking at the MDC, but wondering how it compared to the 451 unit. Now, not only do I know the differences, but I also have an in depth review. I can't agree with you more, features, ease of installation, and price - seems like a no brainer to me. I know which cruise control will go in my Smart.
chasingrabbits is offline   Reply With Quote
SC Seattle now Offers Cruise Control? Britmck Pacific NorthWest Region 22 01-02-2009 12:36 PM
Smart 2008 Smart ForTwo 2300 Mi Cruise Control Tinted ArmRest Smart Cars For Sale Archive/obsolete (?) threads 0 12-30-2008 10:10 PM
Cruise Control Da and Linda smart General Discussion 7 07-26-2008 04:24 PM
Cruise Control Fredvon4 smart General Discussion 2 10-12-2007 07:51 AM
