Oil Filter - Page 2 - Smart Car Forums
post #11 of 24 (permalink) Old 11-16-2012, 04:26 PM
Lifetime Member
Kermit's Avatar
Quoted: 6 Post(s)
I normally use Mobil1 but I keep back up Wix filters in stock at home. The Wix air filters I have used lately are Made in China. A big let down :(. Smart has been around long enough now for them to make them. I also use Wix cabin filters.
Kermit is offline
The Following User Says Thank You to Kermit For This Useful Post:
kennyrayandersen (04-16-2013)
post #12 of 24 (permalink) Old 04-16-2013, 11:46 AM
BigWarpGuy's Avatar
Quoted: 108 Post(s)
WIX FILTERS. They did not have prices at their web site.
BigWarpGuy is offline
post #13 of 24 (permalink) Old 04-16-2013, 12:13 PM
Lifetime Member
Kermit's Avatar
Quoted: 6 Post(s)
The prices vary from store to store. I get Carquest which is reboxed Wix.
Kermit is offline
post #14 of 24 (permalink) Old 04-16-2013, 06:08 PM
Quoted: 126 Post(s)
I'm a Mobil 1 filters as well, but the big issue is using a synthetic medium when the intervals are as long as 10K. The paper filters will break down over that time. I haven't cut a filter apart in 30 years, but the old Wiks didn't have enough holes in the center tube, which causes a larger pressure drop across the filter than is necessary (causes more oil to bypass the filter). I don't know whether they ever got around to changing that or not.
kennyrayandersen is offline
post #15 of 24 (permalink) Old 04-16-2013, 07:29 PM
Quoted: 167 Post(s)
Wix makes many different store brand oil filters and is, today, considered one of the better filters made. Don't base your decision on a 30 year old experience.
OliverB is offline
post #16 of 24 (permalink) Old 04-17-2013, 02:44 AM
Quoted: 126 Post(s)
Yor point us well-taken but I have no data to the contrary. I know even back then they wre highly thouht of. At the same time we cut open a Fram. It acrually had rusr on rhe inside! Are they still like that? I dont know but I saw enough and Ive never bought one since. Anyway, that is why I included the caveat.
post #17 of 24 (permalink) Old 05-11-2013, 11:55 PM
Just wanna post an update since I found a Wix mentioned here.
I have been using OE Oil filters and Mobil 1 M108 for a while. My latest oil change was with a Wix 57040 oil filter.
First major observation. Oil pressure at hot idle is LOW, ~ 5psi. I have a a SPA Technique gauge installed for a while. Never had the pressure this low before and this is the only thing that has changed since the last oil change. May swap out back to OE filter to see if it goes away.
VinceLA is offline
post #18 of 24 (permalink) Old 05-12-2013, 04:08 AM
Quoted: 126 Post(s)
this would coincide with our original finding which was there was a large pressure drop across the filter due to insufficient number of holes in the center support and a bypass spring that was set on the high side.
Incidentally many filters have quite a low bypass setting which causes the filter to run in bypass mode most if the time. Most filters will do that during startup, but some do it pretty much all of the time since the bypass is set so low. The Fram we looked at was only around 2 psi (this was for the basic cheap Fram, not the new premium filter that they offer now)! Of course the best is a filter that has lower resistance (generally one with more filter area) so that high filter flow is maintained without a large pressure drop.
post #19 of 24 (permalink) Old 05-12-2013, 04:58 AM
ArthurRW's Avatar
Quoted: 105 Post(s)
I've been using a Bosch oil filter, the case is of heavier gauge metal and the filter media is synthetic, not paper, so it's perfect for extended intervals found with synthetic oils. The gasket is synthetic as well, harder than the rubber found in most filters so you need to check to ensure there's no deformities or it might leak. (past experience)
ArthurRW is offline
post #20 of 24 (permalink) Old 06-05-2013, 01:25 AM
Quoted: 55 Post(s)
Next time I am in Maul-mart I am going going to compare a Purolator 14612 and a 14610.
Acura owners and other use the 14610 instead of the '12. Same specs, just longer....
Used a 3600 instead of a 3614 on my Saturn for years...
mattwithcats is offline
Human Verification
331
Magnetic oil drain plug and oil filter magnets? mvaldes smart Operation and Maintenance 47 06-19-2013 10:30 PM
FS: Unused spin-on oil filter / ABS reluctor rings / paper oil filters phreddyfred Archive/obsolete (?) threads 1 02-11-2012 05:17 AM
Mobil 1 Oil/Oil Filter Rebate - Get either $12 or $15 back, Expires May 31st. GeekGirl Off-Topic Cafe 1 04-22-2011 04:04 AM
451 Oil Filter & Air Filter Smart Pitstop Vendor Marketplace 0 07-31-2009 10:30 AM
Smilies are Off
