Major Trouble with comsumption. Please HELP (450) - Smart Car of America Forums : Smart Car Forum
Old 02-27-2010, 05:01 AM   #1 (permalink)
Good day, i am a smart fortwo owner from the philippines. My smart car was imported from japan. It is the 3 cylinder, 599cc version, 2000 model.. It had 60k plus miles when i bought it. I am having a problem with its fuel consumption. It roughly goes 6 kilometers per liter! I have changed the filters, oil and spark plugs but i still have the same problem. the importer told me that the injectors could be the problem. Can you please help me? How many liters exactly is one full tank? and how much fuel do any of you think one dot in the fuel gauge represent? thanks in advance and hoping for your immediate replies..
bigbossjecks is offline   Reply With Quote
Old 02-27-2010, 06:41 AM   #2 (permalink)
Padawan's Avatar
That's the equivalent of roughly 14 MPG, which I find very difficult to believe unless there is something incredibly wrong with the fuel system.
I think it's more likely that you are not calculating the fuel economy properly. To get a good indication you need to do the following:
- Fill up the car and record the mileage (or reset trip meter to 0)
- Drive car until empty
- Refuel (preferably at the same pump) and note amount of litres pumped
- Note the mileage on the trip meter
- Divide the number of kilometers travelled by the litres pumped
- Repeat this process several times and find the average
This site makes it really simple to track your fuel economy: http://www.fuelly.com
Old 02-27-2010, 07:40 AM   #3 (permalink)
lebikerboy's Avatar
The tank is only 22 litres. Here's another fuel economy monitoring site...
www.spiritmonitor.de/en/
Old 02-27-2010, 07:54 AM   #4 (permalink)
GHammerly's Avatar
Could have any of these problems.
-Damaged or plugged up catalytic converter.
-Bad oxygen sensor.
-Dirty fuel injectors.
-Ignition timing off
-Exhaust valve seals leaking oil causing carbon build up at exhaust ports.
-Extremely low compression (Worn rings or leaky valve seats)
-Running too rich for some reason. (ECU problem, exhaust restriction, O2 sensor, wrong fuel injectors, etc.)
-Some one siphoning fuel from your car
Old 02-27-2010, 09:24 AM   #5 (permalink)
reply
thanks for your replies sirs. I will advice the mechanic of your suggestions so that he may monitor and check them. keep your advices coming
Old 02-27-2010, 12:21 PM   #6 (permalink)
mark08859's Avatar
Keep us posted of your progress and/or discoveries.
mark08859 is offline   Reply With Quote
Old 02-27-2010, 03:38 PM   #7 (permalink)
geosynch's Avatar
Unfortunately, Japan is kind of notorious for dumping its older cars on unsuspecting developing countries. In Japan, once a car gets to 60K km, it is scrutinized more frequently at license renewal time. Once certain problems develop, it is extremely difficult to get a car re-certified to drive on the road.
I've seen mini-buses that had a previous life picking toddlers up for day care, painted with cute little scenes and with markings from its home prefecture way out in the African bush. Or on some remote island in Tonga.
Good luck. The suggestions above or all good ones and the right places to start looking.
geosynch
major problems w/smart w/in 1st yr. HELP short93106 smart Operation and Maintenance 26 11-09-2009 11:50 PM
Two major complaints about my SMART jetdok5 smart General Discussion 33 04-25-2008 05:11 PM
Engine failures, major problems any? bwimpee smart Operation and Maintenance 4 03-21-2008 12:37 PM
Major snow storm wis and Il. rwj53 smart General Discussion 4 02-06-2008 08:11 PM
MAJOR BUG ENCOUNTERED during test drive stevenvillatoro smart General Discussion 28 01-18-2008 03:10 PM
