Cabin air filter (don't pay high prices!) - Page 4 - Smart Car of America Forums : Smart Car Forum
Old 02-05-2009, 03:39 AM   #31 (permalink)
NeWave's Avatar
that's why you just replace the filter while it's still new, then they'll have nothing to go on.
Plus, the likelyness of your motor going out under warranty is, well.. not likely. But if you wanna be paranoid, you can replace it with the "genuine" filter until warranty is up, and then do what you want with your own freggin car :P
Old 02-17-2009, 10:14 PM   #32 (permalink)
spdickey's Avatar
For those who think Bosch is better than Fram for a A/C cabin air filter.
Bosch P3785 Cabin Filter
Amazon.com: Bosch P3785 Cabin Filter: Automotive Amazon.com: Bosch P3785 Cabin Filter: Automotive
$19.76
Product Description
Original equipment fit and quality for cleaner, healthier passenger cabin air. Pollen and harmful substances inside a vehicle can be up to six times more concentrated than outside. Bosch Premium Cabin Filters prevent harmful spores and pollen from entering the vehicle interior and keep passengers and downstream HVAC components protected. A cabin filter works much like the filter used with your furnace and/or air conditioning system in your home. Replace your cabin filter with a Bosch Premium Cabin Filter and trap close to 100% of airborne contaminants before they enter the interior of your vehicle through the heating and air conditioning system. Image(s) and description shown is a generic representation of a BOSCH automotive-air-conditioning-refrigerant part. Your part may or may not look the same.
Old 02-28-2009, 07:01 PM   #33 (permalink)
fmaxwell's Avatar
Originally Posted by jetfuel View Post
if there's not one then I will suggest you find proof that the filter that you, the DIY guy used, was approved, just in case Murphy decides to take residence in the fan motor and your center declines you warranty consideration for the use of non approved parts...
That's a misconception. The Magnuson-Moss Warranty Act specifically prohibits manufacturers from denying warranty claims because an aftermarket part was used. They only way that they can deny the claim is if they can show that the aftermarket part caused the failure.
From an FTC publication explaining the Act to businesses:
Generally, tie-in sales provisions are not allowed. Such a provision would require a purchaser of the warranted product to buy an item or service from a particular company to use with the warranted product in order to be eligible to receive a remedy under the warranty. The following are examples of prohibited tie-in sales provisions.
In order to keep your new Plenum Brand Vacuum Cleaner warranty in effect, you must use genuine Plenum Brand Filter Bags. Failure to have scheduled maintenance performed, at your expense, by the Great American Maintenance Company, Inc., voids this warranty.
That's a pretty close analogy to what we are discussing here, involving a filter (cabin air filter or vacuum bag) and an electric blower assembly.
Old 03-15-2009, 03:09 PM   #34 (permalink)
LittoDeviL's Avatar
..I do..your restricted air filter (not you, but in general) created a major stress on the fan motor allowing it to overheat which in turn melted some of the winding coating, pitted the armature as the brushes bounced up and down from the heat and all of this made the motor less efficient and that's why you are not getting as much air flow as before and that's why your feet are cold....or something like that....this is at the most extreme of conditions..the one that the warranty claims guy will like to hold on so they don't have to pay..
jetfuel
Jetfuel, I'm sorry but I first have to.. then go..
I'm sure your point is very valid, but in my OPINION, I believe it's "reasons out of context".
In all reality if that did happen to me just because of an air filter... by god... I would have bigger issues in life to worry about and if a dealership had that type of attitude THEY would have more problems to worry about then my fan that broke.
All honesty I don't think I can find a dealership, especially a smart one that is going to tell me that they are going to blame my air filter for the cause... now if I didn't have one and all this junk started flying around then..
I do have to find godfather's comment funny... the whole thing with the oil filter causing the problem with the throttle bodies or the other way around ;) lol...
By the way my warrentee expires in 5,000 miles so I'm not too worry about it... but my opinion doesn't change
Actually I plugged in one of those defective scangauges and it triggered a check engine light, the dealership reset it for free and my maintainance light. Very nice guys at SF SMART... and if I had the problem with the fan and aftermarket air filter I'm equally certain that they have the knowledge to know that it's not the filter's fault.
But.. of course.. legally if they wanted to be a pain in the butt I'm sure they could pull a trick out the basket and say what you mentioned, but my chances of that is slimmer then trying to win a traffic court case in a written by trial of decleration.
Cheers!
Larry
LittoDeviL is offline   Reply With Quote
Old 03-17-2009, 05:08 PM   #35 (permalink)
sheureka's Avatar
Does anyone know anything about Wix filters? Those show up with the smart 2008 match at amazon.com and they have the smart match on their website at WIX Filters : Cabin Interior Air Filters. They're a little more expensive than the Fram or Bosch. - sheureka
Old 04-19-2009, 06:51 PM   #36 (permalink)
churpee's Avatar
Just put in the fram cf 10132 took all of2 min at that--replaced at almost the 1 yr mark looked the same as oem -i am sure it will do as good as oem- btw oem did not look that bad.
churpee is offline   Reply With Quote
Old 06-10-2009, 09:14 PM   #37 (permalink)
Which direction is up on the FRAM air filter
The FRAM Smartbreeze air filter isn't labeled very well. On the Sienna, which direction faces up?
paulsunday2 is offline   Reply With Quote
Old 06-11-2009, 05:55 AM   #38 (permalink)
A Toyota Sienna?
Old 06-11-2009, 06:23 AM   #39 (permalink)
MPrice2984's Avatar
The Toyota Sienna / Camry / etc cabin air filter works very well. When you install a new filter install it with the pleats running horizontally (I doubt it really makes any difference). The one I'm using is a Purolator and I was amazed at the amount of trash it collected in 10 months / 22k miles.
MPrice2984 is online now   Reply With Quote
Old 07-14-2009, 03:21 PM   #40 (permalink)
CABIN AIR FILTER OPTION at autozone!
STP # caf1766 at autozone- is a perfect fit- same size!!! I paid 20.99!!!!
coreyeh is offline   Reply With Quote
cabin air filter, cabin filter
Changing cabin air (activated charcoal) filter Ron F smart Operation and Maintenance 32 08-21-2011 08:12 PM
Barrett Jackson Auction prices not as high dd1 The Car Lounge 6 01-19-2009 06:51 PM
[Cabin] air filter alert... jetfuel smart General Discussion 31 12-05-2008 07:33 AM
Breathless high flow air filter coming soon. lowndex smart Modifications 19 10-05-2008 12:47 PM
High gas prices fuel demand for smaller cars jwight The Car Lounge 8 04-28-2008 09:46 PM
