Just did my installation using Infinity 6022i speakers. Really great bang for the buck mod, it's a
HUGE improvement over the stock speakers and I highly recommend doing it.
I made a few adjustments installing the 6022i speakers since they're not drop-in's and have mismatched mounting points.
- removed mirror and door panel per DIY (without removing weatherstripping)
- peeled back insulation
- removed stock speaker and drilled out stock speaker cover
- Dremeled half of the mounting points of the old speakers to form a circle
- positioned and centered the 6022i's and outer mounting plate
- drilled guides for the included smaller screws directly into the door panel, starting at the top, bottom, then sides. The door panel is actually quite thick and the screws drive and hold perfectly. Used a bit of locktite and didn't need any of the mounting or adaptor plates.
- put a few crimped plugs/tape in lieu of the stock connector
- reassemble and voila, sound is 1000% better than the muffled stockers
TIPS: while you're in there, I highly recommend taping down the wires underneath that come through the insulation. This removed buzzing we were having with stereo and it's what the dealer do to solve that issue. I actually mimicked it on the left side when I saw what they did on the right.
Also, to easily get the leading doorskin edge back on, keep your window rolled down and as you're trying to slip the front portion on, use a flatheaded screwdriver to leverage the skin's lip onto the door. The panel is quite flexible so very very little leverage is needed to slip it back on, you'll have to do this on from the inside.
Cheers
