Save the Jack (Aux In) - Page 2 - Smart Car of America Forums : Smart Car Forum
Old 08-20-2009, 10:29 PM   #11 (permalink)
i cant honestly say i will be swapping my radio in in the next few days ill take it apart and get some pics
rexxxlo is offline   Reply With Quote
Old 08-21-2009, 09:08 PM   #12 (permalink)
Dont Feed The Trolls ^Mod
jediknight36's Avatar
well?
Old 08-22-2009, 06:31 PM   #13 (permalink)
I pulled it put today. I cant reach the end of the plug that is connected to the glove box. Is that plug able to connect to an 1/8th inch plug?
Old 08-22-2009, 09:48 PM   #14 (permalink)
I'm a little confused what you're having an issue with. The jack that comes stock in the glovebox has two ends: one on the stereo side and one on the glovebox side.
If the issue is that you can't get to the glovebox connector to remove it, you're working from the wrong end. The glovebox connector has an unusual washer arrangement around it from the glovebox side (right there visible from the passenger seat) where the the center/top piece pops up to allow the surrounding/bottom fingers to decompress so they can release from inside the ledge of the mounting hole. The connector will drop out the back of the hole if it's quick about things.
The standard connector size in the glovebox is 3.5mm (reference: smart Operator's Manual).
First image is the grommet apart, second image is back together.
Click for higher resolution image.
Last edited by John_H; 08-22-2009 at 09:58 PM. Reason: Found the pictures I took a long while back
Old 08-23-2009, 07:01 AM   #15 (permalink)
Very helpful pics John, but I have to wonder what wierdo came up with that design?
Old 08-23-2009, 10:24 AM   #16 (permalink)
It's a great design for blind-mounting something into an otherwise inaccessible hole. If only your average Joe (John?) knew how to identify and use it properly.
Old 08-23-2009, 12:13 PM   #17 (permalink)
Not sure what the plan is here but if you need some extra aux cables to play with, send a PM to Napolean12.
Old 08-24-2009, 04:15 PM   #18 (permalink)
cubefx's Avatar
Jedi,
What are you trying to accomplish by installing a splitter behind the glove box plug?
Old 08-24-2009, 05:23 PM   #19 (permalink)
What I wanted to do is split the aux input from behind the stereo so that I can have my XM radio always connected to it but if I want to listen to my iPod, it is connected via the glove box and I can pull it out and play it. I was hoping to do this without splicing
Old 08-24-2009, 07:25 PM   #20 (permalink)
cubefx's Avatar
Do you still have the stock radio or upgraded to aftermarket one?
Save Our Tubes (De Dion that is). a2jack smart Operation and Maintenance 96 01-21-2011 07:15 PM
Spare - Jack - Wrench - Jack Points Djinn smart Operation and Maintenance 30 11-16-2009 09:57 AM
I love the world and i want to save it. happygolucky213 Off-Topic Cafe 147 05-13-2008 01:07 PM
MP3 Jack Carnut smart General Discussion 5 02-16-2008 03:42 PM
MP3 Jack Location 2smart4u smart fortwo (451 - US vehicle) 4 10-27-2007 08:58 AM
