P0455
Normally, a gas cap, for sure. It will still cost you $$$ at a shop. To be sure of course this could be a result of a damaged(open)line in your evap system.
Smart Magus
The Following User Says Thank You to Smart Magus For This Useful Post:
PO072 showed up on my scangauge after airco quit, no outside temp, check engine light. Turned out to be loose instrument cluster connection after cruise control install. PO072 not on Evilution list.
Louis
The Following User Says Thank You to louis bolieu For This Useful Post:
Louis
The sheet I have indicates P0072 is not related to the instrument cluster. It's listed as: Exhaust Valve Control solenoid Circuit Range/Performance Bank 1
The Following User Says Thank You to Woody14619 For This Useful Post:
Curious; the most common definition I can find (doesn't mean it's right) is: P0072 Ambient Air Temperature Sensor Circuit Low Input
Another list shows the P0xxx codes as generic powertrain items.
