smart OBD code listings - 451 model - Page 3 - Smart Car of America Forums : Smart Car Forum
Old 11-16-2009, 01:35 PM   #21 (permalink)
Scan Codes not in lists
I just got Codes P2121 and P2138. Anyone have any idea what they are?
gshapow is offline   Reply With Quote
Old 11-16-2009, 02:38 PM   #22 (permalink)
chumly's Avatar
I just got a check engine light ,according to scan gage,I got codes( u0002 High speed CAN communication bus(+)open).Also code u0146(Lost communication with Gateway "A").Does anybody have any idea where or what to look for ? Out of warranty, need to do this myself if possible.
chumly is offline   Reply With Quote
The Following User Says Thank You to chumly For This Useful Post:
Janstheman (05-03-2011)
Old 11-16-2009, 03:27 PM   #23 (permalink)
chumly's Avatar
Well, I had just restarted the car and the light went out.I changed the scangage to check voltage and it was acting weird .I drove it around and the voltage is going up and down from 14.2 to 13.5.After turning off the heater fan it seemed to straighten out .Last week the fan wasn't working but after removing and spinning it,it started to work and has worked normal ever since.It was still working o.k.when this happened, but when I turned it on with the engine off ,the voltage dropped to 12.5 which still seemed normal.Any ideas? At least if it is the fan motor ,it is easy to change but the motor shouldn't go bad that soon (25000 mi.) ,just after warranty expires.
Old 11-16-2009, 03:50 PM   #24 (permalink)
Google shows P2121 Throttle/Pedal Position Sensor/Switch “D” Circuit and P2138 Throttle/Pedal Position Sensor/Switch "D"/"E" Voltage Correlation. Assume that is valid for the smart 451s.
Old 02-25-2010, 08:45 AM   #25 (permalink)
from the scan gauge website P0915 Gear Shift Position Circuit Range/Performance I have this code right now. Waiting on the dealer to call me back...GRRR.. I have a trip I need to leave on in a couple hours. Can anyone confirm this as the correct description for this code?
tjsean0308 is offline   Reply With Quote
The Following User Says Thank You to tjsean0308 For This Useful Post:
Old 03-03-2010, 09:07 AM   #26 (permalink)
wahi's Avatar
(reposted in new thread)
wahi is offline   Reply With Quote
The Following User Says Thank You to wahi For This Useful Post:
Old 03-04-2010, 12:52 AM   #27 (permalink)
I got some from 452, transmission area;
P203B - Actual position sensor of incremental sensor and turning angle sensor.
P2031 - Transmission; Incremental sensor.
P2035 - Turning angle sensor adaption.
Any one can help please?
peterapache is offline   Reply With Quote
The Following User Says Thank You to peterapache For This Useful Post:
Old 03-30-2010, 09:21 AM   #28 (permalink)
got a code po 455, can any one tell me where the purge valve is located, is it on top of the fuel tank?
ricks auto is offline   Reply With Quote
The Following User Says Thank You to ricks auto For This Useful Post:
Old 03-30-2010, 10:16 AM   #29 (permalink)
What year?
The Following User Says Thank You to chieftmc For This Useful Post:
Old 04-01-2010, 11:25 AM   #30 (permalink)
sorry, 2005, 451 SERIES, MERCEDES MOTOR, THERE IS A VALVE ON THE CARBON CANISTER AND A VALVE ON THE LEFT REAR CORNER OF FUEL TANK, ARE EITHER OF THESE IT? THE DIAGRAM ON THE CAR DOESNT SHOW ME SQUAT
Code 24 rpcrichton smart Operation and Maintenance 2 11-19-2008 03:10 PM
Fraudulent eBay Listings (1) sheureka Archive/obsolete (?) threads 10 09-03-2008 12:19 PM
Many ebay listings Karinann smart General Discussion 1 07-17-2008 10:35 AM
New 450 parts and accessory listings.. smartcarparts Dealers and Parts 0 05-29-2008 03:52 PM
reservation code smart1 smart News & Rumors 50 10-26-2007 09:37 AM
