turn signal flasher hyper - Page 2 - Smart Car of America Forums : Smart Car Forum
Old 09-14-2009, 02:23 PM   #11 (permalink)
Originally Posted by mvaldes View Post
I've never actually changed it, only disconnected it when taking off the front. But just changing the bulb (Page 258 in the manual) looks pretty simple.
Ahh...THE MANUAL...who would have thunk? bviously, not me!
Old 09-14-2009, 02:25 PM   #12 (permalink)
Originally Posted by jefferios View Post
Has anyone found out out to replace the door's turn signal bulb? Is that an easy task???
Strangely enough, not covered on the Evilution site but it is here: FQ101 : Taking Modification to the Next Level
Old 09-14-2009, 02:29 PM   #13 (permalink)
wow! look at all these cool photos!
do I need to get surgical gloves for the replacement process?
Old 09-14-2009, 02:55 PM   #14 (permalink)
Padawan's Avatar
Originally Posted by theguywiththelongestname View Post
Don't be alarmed when you remove your bulb holder and only find two bulbs (the middle amber one will be missing). This is due to the different design of our DOT tail lamps versus the European versions.
Old 09-14-2009, 05:01 PM   #15 (permalink)
^ exactly...the 451 has a two-bulb tail light assembly. thanks again for the help on this one...
Old 09-14-2009, 05:20 PM   #16 (permalink)
Padawan's Avatar
Originally Posted by a2jack View Post
BTW the exact replacement bulb is available at Wal-Mart.
Went to Walmart, and what do ya know? Both sets of lights were there (GE Standard series P21/5W for the rear tail/brake, P21W for the reverse light). The P21/5W were available at $2.48 a pair.
Yes, interestingly Walmart is the only store I've been able to locate clear W5W bulbs for the front marker lamps. Most retail auto parts stores seem to have stopped carrying the European bulbs such as P21W, P21/5W, and W5W.
Old 09-14-2009, 07:10 PM   #17 (permalink)
I found a replacement turn signal/brake light bulb at Kragen: the Sylvania 7528...same bulb as the 2008 Mercedes C-Class. The stock Phillips P21/5W converts directly to the Sylvania Long Life type...
Also interesting, the 451 smart bulb socket assembly does have three socket positions (as pictured above), but only the topmost and bottommost sockets are utilized. The center socket is empty.
Everything is working fine, and I learned all about smart tailights. Thanks everyone for the helpful input.
Old 09-14-2009, 09:09 PM   #18 (permalink)
The surgical gloves are not needed for the tail lamps but a good idea for the headlamps. The brighter bulbs will overheat if you get oil (from your skin) on them. It is best not to touch them with your bare hands.
Old 09-14-2009, 10:28 PM   #19 (permalink)
ah sooo...just like the audio vacuum tubes in my Fender Bassman guitar amplifier...those too develop "hot spots" due to fingerprints, and can wear prematurely...thanks for the tip...
Old 09-14-2009, 10:42 PM   #20 (permalink)
Sometimes my vacuum tubes get jammed with carpet fuzz.
Just sayin'.
Turn Signal / Flasher Problem lunarx smart Operation and Maintenance 9 09-07-2011 06:15 PM
turn signal relay Unbeliever smart Operation and Maintenance 4 09-02-2009 02:06 PM
Turn signal flasher problem smartdog smart Operation and Maintenance 5 05-10-2009 12:09 AM
behind the turn signal bar... letsgoskatepool smart General Discussion 3 06-23-2008 10:53 AM
Faint Turn Signal Sound rrrucke smart Operation and Maintenance 9 03-09-2008 08:49 PM
