Originally Posted by donnyonee
can we put another gauge in the pod instead of another clock
how about a volt gauge, my scan gauge has one but theres many other possibles
The pod can fit 60mm gauges but it's the depth that is restrictive. Most 60mm gauges has a depth of about 50mm. Plus of course there is the connector behind the gauge, which will add another 5mm to 8mm. Running the harness down through the pod stand might be another challenge to overcome.
I presume the clock runs on a 5V or possibly a 12V. So there must be a way to get a volt kit from Radioshack, wire up a couple of 7-seg display, and should be good to go.
