Actually Autocross a smart!?!?! - Smart Car of America Forums : Smart Car Forum
Old 06-01-2008, 08:58 PM   #1 (permalink)
randyzimmer's Avatar
Yep,
I have.
Two events now.
Went from pretty sketchy, lifting rear wheels and wondering how good Lexan is as a sled - to Pretty Decent!
I have disconnected the Stability and compared times.
1st event, nearly equal.
6 HS 6 Randy Z Smart Car!
63.782 65.930 63.132 63.509 64.031+1 63.132
Above is the proof, only time #3 was ESP off.
#3 was better than #1 and #4 but but not by much.
#s 2 and 5 had a passenger and that was death to the times.
ESP off, felt dangerous and I quit the experiment after one round.
Today, three and a half (3.5) seconds improvement!
The only engine mod was the new pooper but the time difference isn't a matter of increased power.
3 m HS 1 Randy Zimmer Mercedes smart yellow 76.543 76.207 76.401+OFF 73.192+2 72.790 72.790
72.693+1 72.216+1
7 runs.
1st two with ESP on.
Stuck at 76 sec.
Took off ESP, TC and ABS for all runs after.
The 72.2 was a nicked cone but the 72.7 was clean.
Rear wheel lift was gone. In fact, I'm told the front was getting light like it should - think old 911 stance.
The car did not feel tippy and even started to slide a small bit - mostly a push under power still, but manageable with some hint of rotation on lift.
full scores at:
Downloads | 2008 Solo Results | Solo Results
Old 06-01-2008, 09:08 PM   #2 (permalink)
Founder/former Admin.
SMART's Avatar
Are you running on the stock front wheels?
Old 06-01-2008, 09:09 PM   #3 (permalink)
Never Stop!
Carl242's Avatar
I'm looking to get back into Autox once I've broken the thing in. How do you switch ESP off?
Carl242 is offline   Reply With Quote
Old 06-01-2008, 09:56 PM   #4 (permalink)
What are you running for tires?
jrichie is offline   Reply With Quote
Old 06-01-2008, 10:06 PM   #5 (permalink)
Dave777's Avatar
Interesting, but lots of questions, as above...
Tires?
Pressures?
Wheels?
And of course, how'd you turn off the electronics? If you don't do a DIY post on that one with good photos, expect a ton more questions.
Old 06-01-2008, 11:01 PM   #6 (permalink)
mike-in-sa's Avatar
I love the idea of autocrossing my smart. We race a vw scirocco and I'll bet the smart would be a challenge. Who knows, maybe their own class in SCCA.
Old 06-01-2008, 11:04 PM   #7 (permalink)
Make it the manditory NASCAR footprint!! Ok, I's settle for an SCCA class for smarts and ESPN coverage on maybe ESPN?
Old 06-01-2008, 11:23 PM   #8 (permalink)
One more quick question!
What did you do for a 5 point harness or is it required?
madbunny is offline   Reply With Quote
Old 06-01-2008, 11:56 PM   #9 (permalink)
Never Stop!
Carl242's Avatar
In AutoX, no five point harness is required . . . at least not in SCCA
Old 06-02-2008, 06:11 AM   #10 (permalink)
Just a helmet, which you can usually borrow at the track.
