WOW!
93 views and 8 members writing in just a few overnight hours!
Pretty surprised.
Didn't know if I needed to expand on this but I guess I got my answer.
What I did cost me under $400 for ~ 4 seconds of improvement.
In racing terms, that's a bargain!
Background:
Ran the car stock and noted;
ESP engine management pretty good, not invasive like BMW's.
ESP brake force pretty disruptive but OK.
Worse with passenger - initiated with lean?
Ran the car stock with Fuse #11 removed.
Good:
Engine power consistent.
No more single front brake in corner surprise.
Bad:
No ABS means front brake lockup with every application.
6 to 12" of air under rear tires - very disturbing.
No big gain in times to offset danger.
Sound control reported "0" on sound meter.
Now for the changes:
Front tires:
I bought two rear tires ($65 each Tire Rack) and put them on the stock (narrow) front rims.
Push is reduced.
Direction changes are more pronounced.
Braking without ABS is now possible.
Still not great tires but if they hadn't worked out at all, (like, if they didn't fit the rims) I'd have had some replacement rears in stock for the future.
Roll!
Having the basic tendency of the car to lift the rear wheels off the ground was bad.
Front sway bars in stock class are free.
I removed the front bar, and drilled holes just far enough from the bend to get the nut back on.
This was done by grinding flats on both sides until a 5/16" - 3/8" flat was formed and then a small hole bored and then incrementally opened up to the size of the attaching link dia. The inconsistency of the sway bar metal was ruining bit after bit.
Some steel was soft and other parts hard. I drilled from both sides as far as possible then I finally finished up with a carbide burr where the drills refused to drill.
The "new" bar was amazing once reinstalled and transformed the car. Still soft over bumps but stiff in roll (just like it should).
Noise:
Still no dyno data but the $26 chrome tip (install detailed somewhere else) looks and sounds cool.
The H&R springs ($165 Tire Rack) weren't tested alone so the improvement in time for them is unknown and they did not solve a perceived problem other than lowering CG and reducing ESP induced power loss, but if the car didn't need the fuse in to stay healthy, that wouldn't matter anyway.
They are not legal in a stock class
AFAIK (I don't read Solo rules much) and may not be the biggest speed contributor anyway. I'd like to see what someone else finds about them. They do make a change in the car's everyday feel and it looks cuter.
What I only found out yesterday is that lowering changed my front toe form 1/16" in to 1/4" out.
I hadn't rechecked toe expecting the bump steer to be better engineered. I guessed wrong. I'm sure the toe-out made my turn-ins better but that's probably why my MPG isn't so great.
Chances are you could get 75% to 90% of my improvement with the two tires alone.
(I do believe the springs contribute some, but not dramatically - don't know for sure)
More info:
The scangauge showed;
.8 mile course
.020 gal @ 18.5MPG
51 MPH maximum speed
My friend Mike's Shelby Mustang showed a max of 57!
Unfortunately, his time was 10 seconds quicker, 3rd in PAX and I was ~40 of 80.
