Adding a 50 h.p dry NOS system - Smart Car of America Forums : Smart Car Forum
Old 08-29-2009, 08:49 PM   #1 (permalink)
Worked great on my Hayabusa. Should work great on this little engine. System is in. Don't want to try it without a wide band o2 meter hooked up so I can see if its leaning out. Let you know how it works. 50 hp for $300 dollars plus the cost to fill the bottle is not bad. But will the motor hold....As long as it doesn't lean out or over rev it should be fine. The transmission is another story.
justforfun is offline   Reply With Quote
Old 08-29-2009, 09:20 PM   #2 (permalink)
For sale pm for details
Turbo42's Avatar
Kaboom!!! I have a motorcycle shot on mine 12.4 hp at the wheels
Old 08-30-2009, 01:16 AM   #3 (permalink)
I think you used a touch too much dynomite there. Seriously, 50 might be an overload for the trans, or at least the clutch. Hope not, it would be great if it holds up.
smarticus is offline   Reply With Quote
Old 08-30-2009, 04:48 PM   #4 (permalink)
SMARTPLUG's Avatar
It sounds like you are going to let the magic white smoke out if you are not carefull. Bob.
SMARTPLUG is offline   Reply With Quote
Old 08-30-2009, 04:56 PM   #5 (permalink)
banned
Have you set yours up yet?
Old 08-31-2009, 04:07 PM   #6 (permalink)
Gearhead's Avatar
Ahh... 50hp? That's quite aggressive. I'd recommend a piggy-back to the ECU to retard the timing. Without a timing retard and running fat on fuel, the max I would feed into the Smart would be 30hp -- maybe 35hp... I'd raise the RPM window to 3600 -- 4000 before starting the nitrous. A "sneeze" on the Smart intake manifold may not be pretty... It's a real long convoluted intake which might split. If you're using a fogger before the throttle-body, the fuel will probably puddle at the lower junction before the manifold separates into long separate runners -- so do read the O2. You might have to jet the fogger REAL fat to compensate -- and even then you might get a "sneeze" from the puddled fuel. The upstream O2 sensor used in the Smart is a wideband. You might be able to read the Smart's upstream O2 using a ScanGauge.
I'd do the conservative thing and start at 25hp with a fresh set of plugs. I'd read the plugs, check for fuel puddling if you're using a fogger and check into the behavior of the throttle-by-wire throttle body... The last thing you want is for the ECU to close down the throttle while you're still spraying. That's a recepie for a "sneeze" -- and as already mentioned, the Smart's intake manifold may not like it. My Smart will downshift when I press the pedal down all the way -- and the ECU automatically modulates the throttle during the downshift.
I've got a complete nitrous setup from a previous car -- but I went the turbo route on the Smart. Even with my preferred setup (nitrous/fuel direct port adapters on the injectors with high-pressure nitrous feed and separate jets -- not the NOS Nozzle crap) I didn't like the lack of control over the Smart ECU. I kept getting that bad feeling that it was going to do something I didn't want at exactly the wrong time.
Best of luck!
Gearhead is offline   Reply With Quote
Old 08-31-2009, 04:14 PM   #7 (permalink)
Turbo42's Avatar
;) Maybe
Old 08-31-2009, 09:34 PM   #8 (permalink)
GHammerly's Avatar
50 HP shot is a lot for this car, especially with a dry shot, it will lean out the mixture wayyyy too much. If you are going to use this power trick use a wet NOS system.
Your Hayabusa motor may only be 300 cc larger than the smart but when it's making 180 HP it flows more than double the air and fuel than the smart is capable of flowing.
adding LED lightning under car smartfloridadad Interior & Exterior 8 03-08-2009 09:58 PM
adding ac SMARTCAR95 smart General Discussion 5 11-05-2008 08:21 AM
adding lights jimvw57 smart General Discussion 17 11-02-2008 06:56 PM
Adding fog lights lowndex smart General Discussion 3 06-21-2008 05:02 AM
Adding A/C in a Pure? gohoop1 smart fortwo (451 - US vehicle) 3 02-17-2008 06:00 PM
