Adding under-dash interior lights - Smart Car of America Forums : Smart Car Forum
Old 11-20-2008, 08:31 AM   #1 (permalink)
I wolud like to add a couple of small under-dash lights tied in with the dome light as it is so dark with only the upper light.
Does anyone have a suggestion as to were to tap into the circuit with as mininum of fuss?
Thank you in advance
oldbike
Old 11-20-2008, 08:50 AM   #2 (permalink)
Old 11-20-2008, 02:08 PM   #3 (permalink)
SunDiego's Avatar
This is what I did,
http://www.smartcarofamerica.com/for...tml#post106189
Ties into the switched 12v in the fuse box but is not connected with the overhead dome light. Changes to any of 7 colors.
Old 11-20-2008, 02:17 PM   #4 (permalink)
banned
Not knowing what color your smart is, be VERY CAREFUL... I've gone through 3 sets of LED's now trying to find a nice yellow one... and SunDiego I love ya to death but that set you have does not produce a yellow color.
Old 11-20-2008, 02:24 PM   #5 (permalink)
SunDiego's Avatar
The yellow color works just fine but I leave it on white or off white normally. Don't expect to find any LED's that match the yellow of the car.
Old 11-20-2008, 02:26 PM   #6 (permalink)
banned
I actually found some nice yellow ones on Ebay... I'm just not experienced enough to install them...
Old 11-20-2008, 02:28 PM   #7 (permalink)
SunDiego's Avatar
Have fun with that ....
Old 11-20-2008, 02:56 PM   #8 (permalink)
A Good yellow LED is hard to come by, Amber yes, Yellow not so much
Old 11-20-2008, 09:12 PM   #9 (permalink)
What I am hoping for is to be able to tap into the dome light circuit under the dash somewhere, rather than having to go all the way up to the dome light itself. I want the lights to be switched with the doors
I really wish I had a wiring diagram to start with
Old 11-20-2008, 10:01 PM   #10 (permalink)
When I put mine in the back I found out it is wired in a different way than I expected. You have one tap that is hot at all times. The SAM(ECU) then grounds the other tap to turn the light on. When both taps have 12VDC the light remains off.
Fog lights spliced into parking lights patbianchi Interior & Exterior 45 03-21-2011 07:01 PM
adding ac SMARTCAR95 smart General Discussion 5 11-05-2008 08:21 AM
adding lights jimvw57 smart General Discussion 17 11-02-2008 06:56 PM
adding an alarm smartfloridadad smart Modifications 3 08-27-2008 07:10 AM
Adding fog lights lowndex smart General Discussion 3 06-21-2008 05:02 AM
