Adding a vacuum gauge? - Smart Car of America Forums : Smart Car Forum
Old 11-01-2008, 02:19 PM   #1 (permalink)
For all you guys who've thoroughly checked out the engine compartment, is there a convenient intake vacuum line available to splice in a vacuum gauge? Seems like a fair alternative to a ScanGauge, for around $25. Thanks!
Old 11-01-2008, 06:34 PM   #2 (permalink)
HGB
HGB's Avatar
I thought the arrow displayed in manual mode and its behavior has somehow a similarity to a vacuum gauge.
Old 11-01-2008, 06:37 PM   #3 (permalink)
That's just the computer saying it's time to go to the next higher gear. The vacuum gauge (or economy gauge) will hopefully enable the driver to squeeze more mpg out of the car.
Old 11-01-2008, 07:13 PM   #4 (permalink)
JOIN SCOA.YOU'LL BE GLAD
...how? if I may ask?
...jetfuel
Old 11-01-2008, 07:19 PM   #5 (permalink)
HGB
HGB's Avatar
When a car accelerates there is usually a vacuum drop in the manifold and the gauge's needle then indicates that. The opposite is true when one backs off the gas pedal.
By eyeballing the gauge, the driver can get a better feel of the relationship of how much to press the pedal the least amount and also getting a good move forward. Primitive and simple it may be ...but it does help.
Old 11-01-2008, 10:22 PM   #6 (permalink)
24-42's Avatar
I agree with you on the value of a vacuum gauge.
I think it (the vacuum) could be taken off where I put the tee for the dump valve (blow off valve to some). I'll have to see if it is unadulterated
vacuum.
I'll do it when I get time and ambition.
Donald LaFavor
Old 11-02-2008, 12:22 AM   #7 (permalink)
Adding the scan gauge gives you much more information and lots less work. you just plug it in, set a few setting and off you go. Plus it will give you Check Engine codes if they ever come up. Much easier to mount than a Vacuum gauge with the vacuum line too (Just my opinion)
Old 11-02-2008, 07:23 AM   #8 (permalink)
Sex is primitive, no reason to give it up.
adding lights jimvw57 smart General Discussion 17 11-02-2008 06:56 PM
adding an alarm smartfloridadad smart Modifications 3 08-27-2008 07:10 AM
Adding fog lights lowndex smart General Discussion 3 06-21-2008 05:02 AM
Adding A/C in a Pure? gohoop1 smart fortwo (451 - US vehicle) 3 02-17-2008 06:00 PM
