Old 07-29-2008, 05:13 PM   #1 (permalink)
cubefx's Avatar
Drive: Trickcruiser PT, Smart
Air Intake scoop
Hey,
I want to add air scoop.
There is only two available.
Breathless Performance Air Scoop
Our Products at Breathless Performance
Evil Twin Air Scoop
Smart Car Fortwo For two 451 Evil Twin air intake - eBay (item 320269499906 end time Jul-31-08 03:10:28 PDT)
Price is almost the same.
I like the look of the Evil Twin better then Breathless one.
Breathless Air Scoop attaches to the smart with double sided tape, witch is good and bad. Bad is that I would be paranoid to loose it at 90MPH on the road, good is that you can remove it from your car if you decided that you do not like it or want go stock.
Looking from the pictures Evil Twin is using screws to attach directly to the air box (i might be wrong). Does anyone have any input on the quality of the Evil Twin and the way it is attaches to the smart.
Any input on both air scoops will be greatly appreciated.
Thank you.
CUBE
Old 07-29-2008, 05:45 PM   #2 (permalink)
tigerwong58's Avatar
Drive: Passion, '08 SLK
I wasn't happy with the quality of the BP scoop too many bubbles, but BP will send me another once I send this one back.
Old 07-29-2008, 06:29 PM   #3 (permalink)
smartclubsd.com
SunDiego's Avatar
Drive: Smart, C63, CLS55, Chally
The Evil Twin one looks pretty cool.
Old 07-29-2008, 06:47 PM   #4 (permalink)
VinceLA's Avatar
Drive: BMW Race Car, not a R/C.
I have been eyeing the evil twin one as well, which I think is a better design.
If you take a closer look at the scoop, it curves up from the bottom and tapers off into the intake. This actually induces more flow. The tapering off design guides the air flow better than the BPP's. BPP's scoop cups the intake almost orthogonal to the surface of the panel. This can cause a higher static pressure pt, thus back flow and eventually turbulence.
Case in pt. Blow at your palm directly with fingers closed up (0 deg). You will notice less air deflected to the side of the palm. Then tilt rotate your palm to about 30deg. Imagine where the air deflects to from the palm at 30deg is the entrance to the intake.
Old 07-30-2008, 10:22 AM   #5 (permalink)
Supporting Tuner
Evilution's Avatar
No. It attaches to the rear arch panel, it isn't really that close to the airbox.
If you remove the rear arch panel you will see the air is ducted forwards and down for about 30cm before going 90 degrees into the airbox.
The air route is so twisted and strangled that I can assure you that no scoop will increase performance.
__________________
Old 07-30-2008, 12:00 PM   #6 (permalink)
SylenThunder's Avatar
Drive: Smart Passion Coupe
I agree with Evilution entirely on this... the possible gain would be so small that the way the piping is routed, any benefit would be lost. What needs to be done is to find a way to make a much less restrictive pipe and get a true cold air intake going. The problem with doing this is where the engine is, and overall space constraints. Right now it looks like the best thing would be to mount an airbox to the rear bumper... but then you won't get forced air not to mention heat accumulation from the engine compartment. Any filter mounted externally is going to have a water problem and where the heck are you going to run the pipes? I will probably the the breathless intake scoop when I get my exhaust and a K&N air filter, but I really don't expect much more than looks from it.
Old 07-31-2008, 11:11 AM   #7 (permalink)
Supporting Vendor
Drive: Corvette Z06, Smart + More
Ours is Fiberglass or carbon Fiber not Plastic.
Ernie
__________________
Breathless Performance Products
For Smart Performance
www.BreathlessPerformance.com
954-925-7725
Old 07-31-2008, 02:31 PM   #8 (permalink)
cubefx's Avatar
Ernie
Ernie,
Few questions.
Is there is any issues with double sided tape? It seems that scoop will create a lot of drag and air resistance.
Is it any chance that you working on the different version of the scoop? I really like shape of EvilTwin, IMHO it is looks more aggressive.
I do not expect any performance improvements, but want to change the look of my smart.
By the way, your exhaust rocks!!!!
CUBE
Old 07-31-2008, 03:41 PM   #9 (permalink)
Drive: Jeep Commander, Cirrus G3
Smart's top speed is limited to 85mph.
It attaches to the panel.
From a purely aesthetic point of view, The Breathless Performance piece looks like it actually belongs on the car. The other one screws in and looks tacked-on. I don't believe the other one looks like it's part of the car, it looks like an aftermarket afterthought.
But that's just me.
Your pal,
Meat.
Old 07-31-2008, 03:45 PM   #10 (permalink)
smartclubsd.com
SunDiego's Avatar
pg. 218 of the manual, speed limit is 90mph.
I went ahead and ordered the Evil Twin, I prefer the looks and it was cheaper. I'll post pictures when I get it.
New Cold Ram Air Intake Scoop Just Out.. BreathlessPerformance Interior & Exterior Styling 62 02-23-2009 09:52 PM
BP Air Scoop and Fuel Lid - Carbon Fiber tigerwong58 Interior & Exterior 7 08-05-2008 09:09 AM
New Cold Ram Air Intake Scoop just released BreathlessPerformance Interior & Exterior 3 06-16-2008 05:59 AM
