Air Intake scoop - Page 2 - Smart Car of America Forums : Smart Car Forum
Old 07-31-2008, 04:55 PM   #11 (permalink)
cubefx's Avatar
Originally Posted by mmmeat View Post
Smart's top speed is limited to 85mph.
Your pal,
Meat.
.....Are you sure about that? Because on mine I can actually do 91mph (GPS reading)
CUBE
Old 07-31-2008, 05:00 PM   #12 (permalink)
SunDiego's Avatar
CUBE
90mph according to the manual as I said. Possibly a little more with wind or going down hill.
Old 08-01-2008, 12:27 AM   #13 (permalink)
SylenThunder's Avatar
I clocked mine at 92 on the speedo, 90 on GPS.
Old 08-01-2008, 12:35 AM   #14 (permalink)
Nope. I had read it earlier on Smart's website, but I didn't check the manual. The printed word trumps what a website says, so if the manual says 90 mph then it's 90mph.
Even with WAAS a GPS unit is still interpolating data and guessing at speeds. My Garmin documentation (I've got a 496 that, at times, has said that I can walk up to 10mph) specifically states "Currently, GPS alone does not meet the FAA's navigation requirements for accuracy, integrity, and availability."
Even if your Smart can go 91mph, if you're on public streets you most certainly shouldn't go that fast.
Originally Posted by SunDiego View Post
I went ahead and ordered the Evil Twin, I prefer the looks and it was cheaper.
It certainly looks like it.
If you're going to screw it to your car, you might want to think about getting screw caps so that it doesn't look tacked on.
Your pal,
Meat.
Old 08-04-2008, 01:35 PM   #15 (permalink)
mendo's Avatar
Which Scoop do you think has a bigger opening?
do you think the screen reduces some airflow?
Old 08-04-2008, 03:52 PM   #16 (permalink)
Hard to tell from a picture.
More importantly: I don't believe that either one of them will do anything to significantly increase airflow.
Your pal,
Meat.
Old 08-04-2008, 03:59 PM   #17 (permalink)
mendo's Avatar
Your pal,
Meat.
I saw some data that showed a lower Intake Air Temp and info saying that that could keep the timing from retarding when it gets hot.
Does that Scangauge thing measure Intake Air Temp?
Old 08-04-2008, 05:42 PM   #18 (permalink)
mike-in-sa's Avatar
Yes, the scangauge measures IAT and timing. So you should be able to see the results right away.
Old 08-11-2008, 11:45 PM   #19 (permalink)
PJJSR's Avatar
Hey,
I want to add air scoop.
There is only two available.
Breathless Performance Air Scoop
Our Products at Breathless Performance
Evil Twin Air Scoop
Smart Car Fortwo For two 451 Evil Twin air intake - eBay (item 320269499906 end time Jul-31-08 03:10:28 PDT)
Price is almost the same.
I like the look of the Evil Twin better then Breathless one.
Breathless Air Scoop attaches to the smart with double sided tape, witch is good and bad. Bad is that I would be paranoid to loose it at 90MPH on the road, good is that you can remove it from your car if you decided that you do not like it or want go stock.
Looking from the pictures Evil Twin is using screws to attach directly to the air box (i might be wrong). Does anyone have any input on the quality of the Evil Twin and the way it is attaches to the smart.
Any input on both air scoops will be greatly appreciated.
Thank you.
CUBE
here is a pic of my EVIL TWIN
http://www.smartcarofamerica.com/gal...p?imageid=4307
PJJSR is offline   Reply With Quote
Old 08-12-2008, 05:49 PM   #20 (permalink)
bad bp
i ordered one from bp, waited a week they never sent it called and the had no record not a reliable comp!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
dt1977 is offline   Reply With Quote
New Cold Ram Air Intake Scoop Just Out.. BreathlessPerformance Interior & Exterior Styling 62 02-23-2009 09:52 PM
BP Air Scoop and Fuel Lid - Carbon Fiber tigerwong58 Interior & Exterior 7 08-05-2008 10:09 AM
New Cold Ram Air Intake Scoop just released BreathlessPerformance Interior & Exterior 3 06-16-2008 06:59 AM
