Aluminum foil and jelled SLIME on the oil screen - Smart Car of America Forums : Smart Car Forum
Old 03-10-2012, 06:08 PM   #1 (permalink)
Mad about smarts and Cats
BB Benz's Avatar
I had removed the oil plug with the pressed on oil screen cylinder on it in preparation for installation of the Fumoto oil drain valve.
I was horrified to find a piece of aluminum foil sucked into the hole on the end of the screen. In addition, there was a kind of jellied slime clogging up some of the screen!
It has been suggested that the screen is unnecessary. From this experience, not only will I continue to use the screen, I will now feel obligated to remove the Fumoto valve to Check and clean the oil pump intake screen. This really is a neat design as with other designs, you would have to drop the pan to check and or clean the oil pick up screen. The piece of aluminum foil was almost the size of a nickel sucked inside the open end of the screen.
I've switched to Pennzoil Ultra which is supposed to keep the engine as clean as a Ferrari. come on, I know you've seen the ads.
BB Benz is online now   Reply With Quote
Old 03-10-2012, 06:12 PM   #2 (permalink)
CT Chapter President
smartcar111's Avatar
Uh-oh! I think you should get a Blackstone test during your next oil change! I wonder what's going on in there!
smartcar111 is offline   Reply With Quote
Old 03-10-2012, 06:13 PM   #3 (permalink)
To the XCAPEPOD!
rfernatt's Avatar
I think I'd be sending that oil off to be tested and see what's in it.
Old 03-10-2012, 06:23 PM   #4 (permalink)
BB Benz's Avatar
That would be a good idea. The aluminum foil is a real puzzler. The oil was about 5000 miles old, and still looked quite good. A dark honey color, but certainly not black. The jellied residue is somthing I've never seen before, but I've never inspected an oil pick up screen before, being inside of the oil pan.
Needless to say, I used JB weld to glue the intake screen onto the end of the Fumoto oil drain valve.
Old 03-10-2012, 06:33 PM   #5 (permalink)
127K+ miles of smiles
WhiteNBlack08's Avatar
What color was the slime? Was it milky brown in color? That could signal a blown head gasket. The foil is a real puzzler, as far as I know, the head gasket is MLS, so it shouldn't have a foil layer. Don't know what in the engine would be foil? Hope I'm wrong....
Old 03-10-2012, 06:41 PM   #6 (permalink)
BB Benz's Avatar
dark honey colored gel. Translucent. Not milky brown. I hope you are wrong too, WhiteNBlack08. If there were a blown head gasket, I would expect the oil to appear to be a different color altogether.
Old 03-10-2012, 06:42 PM   #7 (permalink)
Possible that the oil you used to fill with had Oil Bottles with a Foil seal? It may have fallen out while filling the oil.
This is a Rotella 5Qt. Oil Bottle.
Brutal Force is offline   Reply With Quote
The Following 10 Users Say Thank You to Brutal Force For This Useful Post:
chieftmc (03-12-2012), deepblueQ (03-12-2012), forestacademy (03-10-2012), jefferios (03-11-2012), jwight (03-11-2012), kennyrayandersen (03-10-2012), mrc59 (03-11-2012), Pee-wee German (03-10-2012), stressed member (03-12-2012), Uptown Dog Co (03-10-2012)
Old 03-10-2012, 07:00 PM   #8 (permalink)
JOIN SCOA YOU'LL BE GLAD
...brutal is right..and as you said "about the size of a nickel" and made out of foil....the protective /seal that is used on most if not all the bottles sold in the world..the slime could be the paper backing that is attached to the foil...
jetfuel...CSI
Old 03-10-2012, 07:01 PM   #9 (permalink)
Padawan's Avatar
This was my first thought also.
Old 03-10-2012, 07:01 PM   #10 (permalink)
BB Benz's Avatar
This was a thin piece of foil. There did not appear to be any plastic film on the aluminum, unless that was the plastic jell on the screen. It removed fairly easily with Brake cleaner.
jellied slime, oil drain plug, oil filter screen
Front lower air foil ontheroad smart General Discussion 16 03-08-2012 08:36 AM
Flat tire - Slime question zmutrux smart Operation and Maintenance 11 02-08-2011 03:37 PM
Screen affixed to oil drain plug mrc59 smart Operation and Maintenance 24 07-01-2009 03:36 PM
After market tire slime Prescott owner smart General Discussion 11 01-15-2009 01:37 PM
Oil Drain Plug Screen SMARTIEPANTS smart Operation and Maintenance 15 02-09-2008 06:47 AM
