Any wheel, tire, suspension changes planned? - Page 2 - Smart Car of America Forums : Smart Car Forum
Old 11-15-2007, 03:26 PM   #11 (permalink)
Wheel Dope
For those who may go shopping for after-market, 3-bolt, gucci wheels, here are some numbers:
Pitch Circle Diameter (bolt hole circle): 112.5mm
Offset (faying surface of wheel to center of wheel): Front – 29mm; Rear – 1mm (one). That is why a front will fit on the rear, but a rear won't fit on the front in a pinch.
Applies to 450 and 451.
Old 12-05-2007, 06:44 PM   #12 (permalink)
Mostly Harmless
MicroNut's Avatar
Potential Tire Size
This link about the Lorinser smart is posted elsewhere, but the info it contains about tire sizes bears repeating here:
Even if no modifications are made to the vehicle’s body, front and rear tyre widths can easily reach 205/40R17 and 225/35R17, respectively, with rim sizes remaining identical.
http://www.zercustoms.com/news/Lorin...rt-Fortwo.html
MicroNut is offline   Reply With Quote
Old 12-05-2007, 07:05 PM   #13 (permalink)
Fredvon4's Avatar
fishrdnc
My research is turning up some bad news... it looks like on Welsmart, SmartsRus, and a few other sites, the wheel offsets for the 451 are very different form the 450... For the 451 series the very limited selection of rims has ET34 or ET37 as the offset listed... Your note about -29 and -1 is correct for the 450 series....
I have not sent a request for info yet still checking internet sources
May drop a question to some of the Brit sites this weekend
Another thing I have not seen is tire diameter concerns...I can not find how the vehicle speed is derived.... tone rings, tranny gears, ??? or how it is calibrated for larger or smaller diameter tires
Tire diameter changes on these electronic cars can have some adverse effects if not calibrated back to actual revs per mile... I am talking the speedo, power management, ESP, tire pressure calculations etc....
When I poke in the range of different tire sizes in a revs per mile calculator the tires Welsmart or SmartsRus recommends have a broad range of revs per mile changed significantly from the factory tire specs...
Still a bunch of research to do... I find it odd that evilution does not have any speedometer re-calibration info
Old 12-06-2007, 04:17 AM   #14 (permalink)
I guess is you stick to the OEM 451 Pulse and Brabus wheels, or the other wheels listed in the 2007 smart accessory brochure, things should go right right out of the box. It might take third parties some time to catch up.
Old 01-10-2008, 12:42 PM   #15 (permalink)
I received the following from Tirerack on some nice looking and correctly made wheels for the 451:
"We will be carrying 1 wheel option for the Smart Cars, the Rial Le mans at $129/wheel and these will be available on 12/07/07. Please go to our website to view this wheel":
http://www.tirerack.com
the wheel has the following dimensions:
15x5 3x112 bolt pattern +24 offset front
15x6 3x112 bolt pattern +25 offset rear
Please contact me at 800-428-8355 ext 697 for any questions and to place your order. Brock Camarata
Alas, they don't have them in a 17, but I do like the wheel.
Smarticus
smarticus is offline   Reply With Quote
Old 01-10-2008, 12:50 PM   #16 (permalink)
have a look at berlin-tuning webpage they have all the things you can want to tune your little bug
hollywood is offline   Reply With Quote
Old 01-10-2008, 04:00 PM   #17 (permalink)
oldgit61's Avatar
wheels
my smartie, with 5 stud wide wheels
used 3 to 5 stud adapter plates.
Tony [oldgit61 ]
oldgit61 is offline   Reply With Quote
Old 01-12-2008, 08:21 AM   #18 (permalink)
Supporting Vendor
I have Lorinser Speedy in bound, two weeks, 10 sets , 17 inch staggard.
Carlssonpro is offline   Reply With Quote
Old 01-12-2008, 07:48 PM   #19 (permalink)
Gortok's Avatar
The Rial LeMans is the one you showed us the other day...
Not bad at all.
Old 02-01-2008, 08:07 PM   #20 (permalink)
will you pm me a price? thanks.
jaxbchSmart is offline   Reply With Quote
Smart car spare tire smartcar smart Wheels & Tires 50 06-27-2009 06:56 AM
new 9 spoke wheel & red interior mr_Cash smart Gallery 3 10-24-2007 08:39 AM
Mr. Toad goes down in flames... a reminder to check tire pressure? The News Reporter The Car Lounge 1 08-16-2007 05:41 AM
