Anyone remove the passenger seat? - Smart Car of America Forums : Smart Car Forum
Old 08-14-2008, 09:40 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
I would like to remove the seats and I cant seem to get the bolt holding the seatbelt to the seat loose on the passenger side. It is a torx and differs from the hex bolt pictured in evilution's tutorial...it also seems to have an extra box/wire adjacent that looks like it would need to be removed along with the seatbelt. I've broken an angled driver already attempting to get the torx bolt off, its on there very, very well, apparently. Anybody have tips or suggestions? Thanks.
logan74k is offline   Reply With Quote
Old 08-14-2008, 09:56 AM   #2 (permalink)
Have you used the proper Torx bit? A T45, perhaps. Typically a socket wrench rather than an angled driver is used. Please remember that the wires on the bottom of the seat include the airbag wires and the weight sensor. If your car is powered up while the airbag is disconnected, you'll have to visit your dealership to get the airbag system reset.
Old 08-14-2008, 10:23 AM   #3 (permalink)
Yes, I used the correct torx bit, the bolt seems pretty well on there. I aplogize for a lack of an image, maybe later on today I can post one.
Old 08-16-2008, 10:48 AM   #4 (permalink)
Get PB Blaster. Spray it on and leave it for 6 hours. It will come out no problem. I have been considering doing this on my next smart and building a dog seat in its place.
Amazon.com: PB Blaster Penetrating Catalyst 16 oz. aerosol: Automotive Amazon.com: PB Blaster Penetrating Catalyst 16 oz. aerosol: Automotive
letsgoskatepool is offline   Reply With Quote
Old 08-17-2008, 02:49 PM   #5 (permalink)
Broken Kid's Avatar
Yeah...planned to take the seat out to install the armrest and couldn't get that seatbelt bolt. Not enough room to get in there... But getting the four bolts along the track and moving the seat forward (without disengaging the cables) worked perfectly!
Broken Kid is offline   Reply With Quote
Old 08-17-2008, 05:19 PM   #6 (permalink)
ZenSpeed's Avatar
I removed the passenger seat to run speaker wires under the carpet (to the back) and it was completely uneventful. Perhaps your tricky bolt was cross-threaded during assembly at the factory?
Note: If you do get the seat loose, be REALLY careful lifting it out of the car; the edges of the mounting brackets are fairly sharp and it's easy to damage the dash if you hit it.
If you're anywhere near North Florida you can bring it by the shop and I'll whack it out with an impact gun.
Cheers,
Johnny
ZenSpeed is offline   Reply With Quote
LinkBack to this Thread: http://www.smartcarofamerica.com/forums/f19/anyone-remove-passenger-seat-12596/
Smart Car Blog: Smart Car Accessories This thread Refback 08-14-2008 10:47 AM
Velcro on back of passenger seat? akiranakayama Interior & Exterior 18 12-05-2010 08:29 PM
Reclining the passenger seat backward EdwardDennis smart Operation and Maintenance 25 10-24-2008 03:35 PM
Why does the passenger Seat go back farther than drivers?? mnext02 smart General Discussion 14 08-03-2008 03:35 AM
