Originally Posted by jwight
It won't work!
Of course there are tools for "pin" insertion/extraction... and that one, as it states, is for "D Sub Pin" insertion/extraction. There are thousands and thousands of different types and styles of pins.
The ones used here are specifically called "Micro Timer II" but more commonly referred to as "mini-ISO". The tool is TINY. I guarantee you that D Sub Pin tool is a good 4 times too large to work.
The Area451parts.com website instructions gives links for the "proper" tool out of Germany. And as I've said before, I have that tool... and I use the staples. The staples cost 1/3 of a cent and they work BETTER than the official tool. Some people have mentioned jewler's screwdrivers but honestly I think using those will cause undue wear on the connector as it really just BARELY fits. If you have to "wedge", "jam" or otherwise force the tool in at all, it is too big! The staple recommended in the instructions, a Bostich 3/8" "Heavy Duty Staple" (not a construction or staple gun staple) is pretty much perfect. As I said... BETTER than the "real" tool, which I have here but don't use because it doesn't work as well. It looks prettier! But that's my only justification for the $40 I spent on it.
- Steven
