Boot LED's and a rear 12v outlet - Smart Car of America Forums : Smart Car Forum
Old 01-01-2009, 04:50 PM   #1 (permalink)
banned
I installed a 12v outlet today so I can get power from the rear of my smart. It's just run to a constant slot on the fuse panel. As you can see, it's not that clean but it is functional... the drill bit wasn't sharp enough and ragged the plastic... I'll do another panel in the future.
Then I tackled the LED's in the ceiling of the boot area... again, I'm not an expert by any means and as it turned out I'm not happy with some aspects of the install... specifically the location of the switch...
My problem is this... the LED's were advertised as ultra bright... and there's not NEARLY ENOUGH LIGHT... The setup is 4 LED's daisy chained with a 15A fuse and a switch in the front... it's all run directly to a constant 12v slot on the fuse box at the front of the car. Is there anything I can do to increase the brightness????
Old 01-01-2009, 06:28 PM   #2 (permalink)
Get us the night shot of the LEDs on please
Old 01-01-2009, 06:42 PM   #3 (permalink)
banned
Best I can do... my camera's not night friendly... The illumination is enough to make out the features of the boot area but not bright enought... maybe 10 percent of the dome light...
Old 01-01-2009, 06:47 PM   #4 (permalink)
HGB
HGB's Avatar
Looks like two black cats in a coal mine.
There's got to be brighter LED lights on line that can be substituted for your original ones.
Old 01-01-2009, 07:01 PM   #5 (permalink)
Carlarm's Avatar
How much current are you pushing through the LEDs vs. their specifications? Typically, one puts a current limiting resistor in series with an LED. With four LEDs in series the current (and thus brightness) will depend on 4x junction Voltage vs. battery Voltage and will be very dependent on ambient temperature and charge of battery. If the current is too low I'd put pairs of LEDs in parallel and use a series resistor of correct ohm and wattage value.
Old 01-01-2009, 07:08 PM   #6 (permalink)
banned
The current is 12v... Following the directions off Evilution I understood that optimum volts for LED's is 3 so you split it on 4 LED's... The LED's are regular 5mm LED's... I don't believe they were setup with a resistor but I can't tell you for sure.
Old 01-01-2009, 07:34 PM   #7 (permalink)
Carlarm's Avatar
12V means 12 Volts and does not say what current is going through the LEDs. You need a multimeter to measure this. This should be something like 20 milli-Amps or whatever the specs are. My guess is that you'll measure something like 5 milli-Amps. If you go to Digi-Key Corporation - USA Home Page and enter the part number of the LED you'll be able to find the spec sheet.
Current (I) is determined by the equation I = V/R. LEDs have a very low resistance but also have a junction Voltage. If each LED has a junction Voltage of 3 and the battery is producting 13 Volts you've got 1 Volt left over to produce light. The junction Voltage is temperature dependent. If you use a series resistor the current will be determined by the resistor and not the LEDs.
Old 01-01-2009, 07:39 PM   #8 (permalink)
jefferios's Avatar
When I see LED Flashlights, I also notice they have a Magnifiying Lens, this helps to spread out the light and possible make the output appear brighter. Just a thought.
Old 01-01-2009, 07:53 PM   #9 (permalink)
JOIN SCOA.YOU'LL BE GLAD
LED lights have a very small current draw...try installing a regular light bulb in the circuit and see if they become brighter...
..the 36 LED tail light set up for the 65 mustang has a light bulb (covered with black tape) for that reason....without it they're just dim...
jetfuel
Old 01-01-2009, 08:10 PM   #10 (permalink)
jetfuel
You may be onto something, Other instals that were similar but worked used the front dome light.
HowTo: Ultimate Smart Trunk Light DIY (lots of pics) - smart USA insider
Dog Carrier in Boot Area rrrucke smart General Discussion 15 01-04-2009 03:03 PM
Interesting cigarette outlet module letsgoskatepool Interior & Exterior 2 08-13-2008 09:44 PM
Boot/Trunk Box bumblebee smart Gallery 53 07-18-2008 07:47 AM
451 Seat & Boot Cover for Dog Owners rrrucke Interior & Exterior 8 05-28-2008 02:48 PM
New exhaust outlet... randyzimmer Interior & Exterior 13 05-10-2008 10:58 AM
