Button bank mod DIY (garage opener/boot release) - Page 3 - Smart Car of America Forums : Smart Car Forum
Old 05-05-2009, 06:10 PM   #21 (permalink)
Very cool of u to take the time to photo and post.
beautyforashes is offline   Reply With Quote
Old 05-05-2009, 06:54 PM   #22 (permalink)
Padawan's Avatar
If anyone is looking for a spare button bank to modify, I have one available. It's virtually brand new, and has heated seat buttons as well as three blanks. Feel free to send me a message or email me.
Old 05-20-2009, 11:10 AM   #23 (permalink)
OTD3 lifetime Member
jsenka's Avatar
Any new ideas on the garage door remote switch workaround?
jsenka is offline   Reply With Quote
Old 05-26-2009, 10:49 PM   #24 (permalink)
Found the problem....
I looked at Evilution's button bank info again and he mentioned that the switches (except for the end ones) are momentary switches.
I took a multimeter to my button bank and confirmed that the switches are momentary closed switches and not momentary open switches like the discussions about transistors would leave you to believe.
After re-looking at Cubefx's mods I think I found the problem. You need to disconnect the "hot" wire from the wiring harness. The garage remote should be connected instead of the hot wire, not with it. For example, in Cubefx's mod, you need to snip the blue wire (and cap it) and solder the red wire to it. Otherwise the car will supply 12V to your remote and depending of how the remote is wired, you could get a current flow through the remote. Snipping the wire let's you use the switch isolated from the car's 12V circuit.
Important note: you don't want to snip the brown wire since all your buttons depend on that for ground.
Finally, I found another good place for the remote. I put mine under the cover that you remove to get to the radio. There's plenty of room and the remote isn't buried down in the metal part of the car. I think it will improve the range.
Hopefully, I didn't miss anything- I'll let you know if I end up with the same battery problem. Good luck and thanks to Evilution and Cubefx for paving the way for the rest of us.
Fritz is offline   Reply With Quote
Old 05-27-2009, 07:07 AM   #25 (permalink)
Gilbert's's Avatar
I never gone that far but i installed the one came from MBZ CLK i might post a picture....
Old 05-27-2009, 09:12 AM   #26 (permalink)
jsenka's Avatar
Thanks Fritz,
I'll be watching for an update.
Old 05-28-2009, 07:01 PM   #27 (permalink)
No workie....
It turns out my version of the wiring has the same problem. The voltage was a little lower, but same general problem. The button bank still applies a voltage to the switch line.
Looking at the button bank circuit card, it might be possible to remove some components to make the switch just a switch, but without a schematic it is too hard (for me) to trace all the circuits and safely do this.
It was worth a try, but I've removed the remote to avoid any problems with trons going to the wrong places.
Old 05-29-2009, 06:33 PM   #28 (permalink)
brett2658's Avatar
what are the empties used for
what are the unuse prewired buttons set aside for by smart?
brett2658 is offline   Reply With Quote
Old 05-29-2009, 07:03 PM   #29 (permalink)
Depends what you have configured.
The center button is the hazards and the buttons to the left and right of that are lock and unlock, respectively, with an LED on the lock button.
The outside two buttons are for heated seats with two LEDs each.
The right side also has TPMS reset (outside) and Alarm motion sensor disable (inside) buttons with an LED for the alarm side.
The left also has a rear fog lamp button (outside) - something you probably won't find in the US - and an unused button location inside of that with a place for an LED but no LED is installed and no pin in the wiring harness that connects to the button bank. Or at least I think that's how those two are configured. There are still a couple components hooked up in the unused switch's path - not sure how they behave.
Old 05-30-2009, 12:57 PM   #30 (permalink)
Padawan's Avatar
On the left side, you have the driver's heated seat to the far left with two red LEDs, then the front fog lamps (with green LED), then a blank spot where the rear fog lamp would be, then the Lock button with red LED
How to install an OEM-style remote garage door opener JimDantin smart Modifications 19 10-21-2011 03:59 PM
Garage door opener Duckhunter smart Modifications 24 08-14-2010 03:24 PM
Wanted: Button Bank Modification Smart_in_Paradise Interior & Exterior 55 09-05-2008 10:54 AM
Biofuels behind food price hikes: leaked World Bank report jwight Off-Topic Cafe 4 07-04-2008 01:28 PM
Bank of America will finance your smart... GABadger smart General Discussion 4 01-19-2008 03:27 PM
