DIY Motor Mount Modification.... - Smart Car of America Forums : Smart Car Forum
Old 04-14-2012, 04:50 AM   #1 (permalink)
Before starting, you'll need:
Floor jack, jack stands, 3M 08609 Urethane, 1/2"x9/16" socket, caulking gun.
As you know, there is a lot of rocking movement created when the engine is in gear and shifting. BMS make a very nice mount that works great - you can instantly feel the difference after its installed, and the install will take you all of 15 minutes. The mount is about $129 plus shipping. Here's a DIY that works nearly as well for about $22!!
I borrowed the idea from a previous car I owned that had a similar problem and a member of that cars forum solved the issue. You'll need to plan on doing this when you can let your car sit on jackstands overnight, but the wait will be worth it - trust me.
Jack up the rear of the car and place a jack stand under each side. I placed them under the frame tube. Then remove the two bolts and nut holding the engine mount in place. If you don't have the proper torx socket - I used a 1/2" x 9/16" socket and it worked fine.
When you get the mount out, you'll understand why you have all of the movement. Here's the stock mount. The rubber flexes esily around the mount because of all the air space.
Pick up some 3M 08609 Urethane which is used to seal car windows in place. Don't confuse this with silicone - this will dry into a much denser and harder rubber. I bought this at Advance Auto Parts
Open the tube, place it in a caulking gun and fill in all of the open space around the mount. Make sure and get it in all corners and air space on both sides of the mount.
Take a piece of plastic and smooth the Urethene out - forcing it into mount as you work it. and that's it!
Let the mount dry at least overnight and re-install back in your car. I used my floor jack to adjust the motor slightly so that the bolts would line up easier when I put it back together.
Is this as good as a BMS mount? Probably not, because theirs is a fabricated piece with a solid rubber mount. Does it make a difference in the way your Smart Car feels when you drive it? Absolutely!
And, you have only $22 into the project.
m3456y is offline   Reply With Quote
The Following 3 Users Say Thank You to m3456y For This Useful Post:
CharlieK (04-14-2012), dancote (04-17-2012), mhornfeck72205 (04-14-2012)
Old 04-14-2012, 05:24 AM   #2 (permalink)
elmosisu's Avatar
Interesting!
I wonder how long this will last until it comes apart? Keep an eye on it and let us know!
elmosisu is offline   Reply With Quote
The Following User Says Thank You to elmosisu For This Useful Post:
jefferios (04-14-2012)
Old 04-14-2012, 06:14 AM   #3 (permalink)
mhornfeck72205's Avatar
I bet if you completely clean it and degrease it with something like brake cleaner, you'll have it last for quite a while. That stuff is tough!
mhornfeck72205 is offline   Reply With Quote
Old 04-14-2012, 06:34 AM   #4 (permalink)
wrumbarger's Avatar
I recall that someone tried this back in 08?
As I remember, the new urethane self destructed after a few hundred miles?
Please keep us informed as to the longevity of your option.
The Following User Says Thank You to wrumbarger For This Useful Post:
jwight (04-17-2012)
Old 04-14-2012, 06:38 AM   #5 (permalink)
The Following User Says Thank You to mhornfeck72205 For This Useful Post:
jwight (04-17-2012)
Old 04-14-2012, 08:30 AM   #6 (permalink)
Did this on a rear transmission mount on an Acura Legend and never had to do it again. I did foget to mention that I cleaned it with carb cleaner first.
Old 04-14-2012, 08:35 AM   #7 (permalink)
silverbrabus's Avatar
Originally Posted by mhornfeck72205 View Post
My thread.
Yeah, keep us posted. That stuff might actually survive. If I remember right it's really soft, like maybe 20A.
Old 04-14-2012, 09:12 AM   #8 (permalink)
I will update.
The urethane is not real soft, but has the consistency of rubber - unlike an epoxy. Like I said in the original post - this was a fairly well known Mod on the Acura Legend forum. For $22 bucks, worth a try and really feels different.
Old 04-14-2012, 11:38 PM   #9 (permalink)
chumly's Avatar
Does it transmit any more vibration at low rpm than stock?
chumly is online now   Reply With Quote
Old 04-15-2012, 03:07 AM   #10 (permalink)
it's hard to imagine (not impossible) that the stuff out of the can would be as good as the stuff out of the oven
kennyrayandersen is offline   Reply With Quote
Motor mount Dale Christensen smart Operation and Maintenance 23 02-17-2012 06:28 AM
Motor Mount?? jim123 smart Modifications 37 08-30-2010 09:43 PM
Motor Mount Anyone? donnyonee storage, obsolete threads (locked) 6 06-18-2010 07:55 AM
motor mount donnyonee smart Modifications 8 06-07-2010 03:34 PM
Another DIY Scangauge mount JThw8 smart Modifications 9 04-25-2008 07:55 AM
