DIY: Painting your headlights - Smart Car of America Forums : Smart Car Forum
LinkBack (13) Thread Tools Display Modes
Old 07-16-2008, 11:55 AM   13 links from elsewhere to this Post. Click to view. #1 (permalink)
cubefx's Avatar
Big Thanks to Kane and his Evilution Guide.
DIY: Painting your headlights.
Disclaimer:
Use these instructions and clear your headlights at your own risk. I will not be responsible for fogged up headlights, broken headlights, melted headlights, or any other stupid things people might do to their headlights. I am also not responsible if you cut yourself, burn yourself, electrocute yourself, or sustain any kind of injury while clearing your headlights. In other words, I will not be responsible for ANY kind of injury or damage (physical, mental, spiritual, whatever) that occur during the process of clearing your headlights.
1. You will need to remove side skirts and front panels.
a. instructions for removing sideskirts:
b. instructions for removing front panels:
FQ101 : Smart Car Modifications
2. Remove headlight:
3. Open headlight:
Remove all the bulbs. Now is the fun part begin.....
I personally prefer heat gun for this job, but you can bake your headlights in the oven. I recommend 200F for 10 minutes on the lower shelf. Preheat oven to 200F, place wet towel on the baking sheet and put headlight on top CLEAR FACE DOWN. Once headlight assembly is heated, I suggest to start to pull from the corner because you can get a good grip, if the headlight does not pull apart, then heat it at 200F again for another 4 minutes, and try again. Keep heating it with short intervals until the headlight can be pulled open. I`m using special plastic tool for prying headlight open, but you can use flat screwdriver. Take your time. It took me about 25 minutes for each headlight to pop them open because I used heat gun and I heated one section at a time. Try not to get gunk on the inside of your headlight.
4. I decided to remove orange reflector, so I just used small pliers to break one out piece by piece.
5. To remove turn signal cover push from the side with small (micro) screwdriver on the tab you see in the photo and cover will just pop out.
6. Use sand paper to remove silver paint from the headlight. I started with 150 grit and finished with 400 grit paper. If you do not do it you have a chance that paint will start to flake.
7. I used KRYLON FUSION for plastic black gloss paint and KRYLON CYSTAL CLEAR flat clear coat. Tip: Spray light coats, wait at least 10 minutes between recoats. I did 3-4 coats of paint and 2 coats of clear. If you have overspray, bumps or any other imperfections you not happy with, just wait till paint is dry, sand it and respray it again.
Also I added red stripes ( but I`m not happy with results, I might repaint it later with red or solid black ).
Once you are happy wit results wait 8 hours before assembling your headlight, so paint will have time to cure.
To be continued
Old 07-16-2008, 11:56 AM   #2 (permalink)
cubefx's Avatar
8. As suggested by Kane at Evilution guide you can reheat old rubber and snap your headlights together, but I decided use new seal to make sure that my light will not fog or leak.
I got rubber butyl / OEM sealer from my local Nissan dealer. Part number B6553-89915. You can also buy it online:
BuyNissanParts.com
search for B6553-89915 and a list should come up. It's the last one on the list.
This is EXACTLY what smart using for they seal. To install new seal you will need to clean your headlight from old seal as much as you can. Be carefull to use GooGone or any similar products on your clear plastic, there is a chance that you might damage it. You will only need to use about 3/4 of the roll for both headlights. Do not put to much of the sealer or you might have a problem to snap two halves together. Preheat seal before you do that.
9. Install your new headlights.
If you have any questions, please feel free to ask.
CUBE
Old 07-16-2008, 11:59 AM   #3 (permalink)
SunDiego's Avatar
Sweet!!!
Old 07-16-2008, 12:04 PM   #4 (permalink)
Agent 99's Avatar
Very nice and BTW I like the red strips.
Agent 99 is offline   Reply With Quote
Old 07-16-2008, 12:07 PM   #5 (permalink)
WilyB's Avatar
Great post, thanks!
Old 07-16-2008, 12:24 PM   #6 (permalink)
bottlerocket's Avatar
That is friggin SWEET!!!!
Too bad I have nowhere near the guts to do this myself, lol
bottlerocket is offline   Reply With Quote
Old 07-16-2008, 07:10 PM   #7 (permalink)
GoMXracing's Avatar
very nice , i was going to do this as well.. notice any differance with lights on at night w/ less reflectivity >? (no chrome/silver) any less bright>?
GoMXracing is offline   Reply With Quote
Old 07-16-2008, 07:31 PM   #8 (permalink)
For sale pm for details
Turbo42's Avatar
hey man leave the red it looks really good im going to smoke my lenses at work
Old 07-16-2008, 07:44 PM   #9 (permalink)
cubefx's Avatar
Nope, there is no difference. I did not sprayed actual reflectors, only plastic housing, so there is no penalty (less reflectivity).
CUBE
Old 07-16-2008, 07:45 PM   #10 (permalink)
cubefx's Avatar
Are you gonna do it before 25th?
Cube
LinkBack to this Thread: http://www.smartcarofamerica.com/forums/f19/diy-painting-your-headlights-11296/
Aussie Smarts - Smart Car Forum for Aussies - Lets talk about This thread Refback 10-12-2008 11:28 PM
smart-Forum This thread Refback 10-11-2008 02:11 AM
painted headlights - smart USA insider This thread Refback 09-18-2008 04:24 PM
Painting Headlight Casings - Club smart Car This thread Refback 08-29-2008 10:25 PM
trinituner.com ::: View topic - Best fix for yellowed/ discoloured headlights? This thread Refback 08-26-2008 11:09 AM
End of August Event - Club smart Car This thread Refback 08-25-2008 01:55 PM
Painting Headlight Casings - Club smart Car This thread Refback 07-22-2008 10:07 PM
Painting Headlight Casings - Club smart Car This thread Refback 07-22-2008 08:57 PM
Painting Headlight Casings - Club smart Car This thread Refback 07-22-2008 08:13 PM
Painting Headlight Casings - Club smart Car This thread Refback 07-22-2008 05:22 PM
painted headlights - smart USA insider This thread Refback 07-20-2008 03:54 PM
painted headlights - smart USA insider This thread Refback 07-19-2008 08:32 AM
painted headlights - smart USA insider This thread Refback 07-18-2008 08:52 AM
Painting calipers BobbyBRD Interior & Exterior 13 10-04-2008 05:26 AM
Thinking About Painting My Smart- Opinions Please MD85255 smart General Discussion 5 06-19-2008 09:45 PM
painting lower body panels graphix1998 Interior & Exterior 20 06-12-2008 11:31 AM
Headlights SloPok smart fortwo (451 - US vehicle) 7 03-01-2008 01:10 PM
