Doug Thorley Exhaust install video - Smart Car of America Forums : Smart Car Forum
Old 06-11-2008, 03:56 PM   #1 (permalink)
Here is a video showing how to install our exhaust system on your Smart.
Thanks
Nick
Admin please make this a sticky
Doug Thorley Headers is offline   Reply With Quote
Old 06-18-2008, 01:39 PM   #2 (permalink)
curtis's Avatar
got mine on the other night
Old 06-18-2008, 01:52 PM   #3 (permalink)
I had mine installed Monday June 16. The installer had the top bolt in the flange won't come out problem but that is a smartville issue. I like the exhaust system a lot, I like the way it sounds and just by the exhaust note I can tell a lot about how the engine is performing.
The Doug Thorley cat-back exhaust is a great product.
Old 06-18-2008, 02:03 PM   #4 (permalink)
Founder/former Admin.
SMART's Avatar
I would be interested in hearing some more sounds clips, any you can share?
Old 06-18-2008, 02:18 PM   #5 (permalink)
smartune's Avatar
I can get you a real-life one...lol
Old 07-20-2008, 04:45 PM   #6 (permalink)
Installed my DT Exhaust today
Thanks to all the DIY posters and a great tutorial by Stuart Berman on SmartUSAinsider, the job went pretty smoothly
This is definitely a job you want to do when the car hasn't been run and the exhaust is cold. I followed the lead of others and did not remove the top bolts on the heat shield. While it did make it a tighter squeeze to get out the others, it avoided the potential problems that have been reported with over-torqued factory bolts on the heat shield that break off when you try to remove them.
Leaving the heat shield in place, I found that there wasn't enough room to get my e-sockets in there but was able to break free the bolt with the 5/16" ratchet wrench for the heat shield bolt attached to the stock muffler and the 3/8" ratchet for one of the cat/muffler bolts. For the other one cat/muffler bolt, I had to put on the box end wrench and grab the open end with my needle nose vise-grips to get enough leverage to finish breaking it loose. A switch to the regular box end wrench completed the loosening of the first one, because there wasn't room to get my particular ratchet (craftsman) to click to a new ratchet position.
The tip about using channel locks to squeeze the muffler hangers through the hanger rubbers made that a simple task after the liberal application of WD-40. (Sorry I don't remember who suggested this, they deserve a hand.)
I did use the bolts supplied by DT, liberally coated with locktight, and the 12mm socket with 1/4" drive for the new installation. (The larger drive wouldn't have fit in the space.)
I'd say it sounds a bit louder than the Mini but not offensively so and most posters say it quiets down a bit after it's broken in. The sound is definite improvement, but I can't say I really saw any performance difference on the first test drive.
Old 07-20-2008, 06:36 PM   #7 (permalink)
Good job. I think you'll enjoy the performance of the DTH exhaust after you've put a few miles on it.
I really like mine and enjoy the exhaust tone--akin to a nice British roadster type of sound, like my old Spitfire.
My car seems to perform better, particularly during the 1st-to-2nd and 2nd-to-3rd shift transitions. I haven't checked to see if it provides any better MPG---but, frankly, it doesn't matter
EdwardDennis is offline   Reply With Quote
Old 07-21-2008, 12:10 PM   #8 (permalink)
DT exhaust
I agree completely. Even if there's no change in performance or mpg, there is enough of an increase in the fun factor to "justify" installing one.
New Doug Thorley Exhaust installed! SmartBill OC Smarties 3 07-25-2008 08:34 PM
Doug Thorley exhaust pre-buy special! smartune Performance & Handling 89 07-20-2008 04:29 PM
Doug Thorley Exhaust cmjars Archive/obsolete (?) threads 17 06-12-2008 01:19 PM
Doug Thorley Exhaust install video Doug Thorley Headers smart Videos 0 06-11-2008 03:53 PM
Doug Thorley Exhaust video Doug Thorley Headers smart Videos 7 04-16-2008 02:58 PM
