drilled airbox - Smart Car of America Forums : Smart Car Forum
Old 02-28-2009, 09:06 AM   #1 (permalink)
fts1966's Avatar
drilled airbox
has any one drilled there air box for more air flow? i have done it on my lincoln and it worked great. an easy and very cheap way to get more air.
just thought i would ask?
frank
fts1966 is offline   Reply With Quote
Old 02-28-2009, 09:11 AM   #2 (permalink)
i wouldnt do that being the engine compartment is rather warm.. the sealed air box is resonably effeicent.. you may be better going with a high flow k+n filter and removing the the sound baffles .. for better air flow..tht will give you the best bang for the buck .. with out going to a cold air intake.
foyfarlow is offline   Reply With Quote
Old 02-28-2009, 09:16 AM   #3 (permalink)
Macaw's Avatar
Also it's a dust vacuum under there....
Old 02-28-2009, 11:05 AM   #4 (permalink)
If you are going to just drill a hole (maybe 2" dia?) and leave it as is, then no pt. However, if you are innovative enough, you can maybe design a air duct to channel air from a colder region to this hole. Keep in mind that the space is really constrained around the airbox area.
Old 02-28-2009, 12:17 PM   #5 (permalink)
The stock intake system from the side is pretty effective with the right air scoop minus the air baffles.
get one that is large enough to really work ,and not one that just looks cool.
remember the throttle body is only going to take as much air as the blade will allow past it .I think the key is to keep the engine as cool as possible,some one should come up with a wide flat scoop that channels air up to the egnine block from under the car just in front of the engine.hmmm maybe i will
smartskate is offline   Reply With Quote
Old 02-28-2009, 12:32 PM   #6 (permalink)
Macaw's Avatar
Only problem with that, is in the winter I scrape bottom in the deep snow and a scoop there would plug up....'cours you could add a de-icer....
Old 02-28-2009, 01:37 PM   #7 (permalink)
frank
Another issue is you'd have to drill below the filter, as the top of the airbox feeds the engine and is downstream from the filter.
Reinstalling the factory airbox. VinceLA smart Modifications 2 02-06-2009 04:48 PM
Smart Airbox agent00mcfly smart General Discussion 8 01-06-2009 07:15 PM
Dealer drilled for front plate holder. How do I fill them holes? Derek Bell smart Operation and Maintenance 7 09-06-2008 04:20 PM
