Originally Posted by nader
i'd be curious to know how much the downward travel has decreased. thats what will affect the ride quality as far as jarring over large abrupt bumps.
Also when you put one or two people in the car it sits considerably lower.
Did you realign it afterwards? if so did it could they get it back to spec or does it require and sort of camber/caster kit?
I'm not sure how much downward travel has decreased, but the KW's come with shortened shocks so suspension travel is still good.
I have not aligned it yet, but Works can align for you. I was in a rush to go to work after the install, so alignment will come later.
If you are in SF, definitely have this done through Works. Pete was great to work with and addressed my concerns throughout the process in a very professional way. I would not hesitate to go back there again.
