Ebiach or H&R springs - Smart Car of America Forums : Smart Car Forum
View Poll Results: Do you reccommend Eibach or H&R springs
Eibach Springs 9 40.91%
H&R Springs 13 59.09%
Voters: 22. You may not vote on this poll
Old 10-14-2008, 09:00 AM   #1 (permalink)
Smartmadness.com
2micro4u's Avatar
Ebiach or H&R springs which brand do you recommend for springs and why?
Do both lower the Smart the same amount?
2micro4u is offline   Reply With Quote
Old 10-14-2008, 09:37 AM   #2 (permalink)
For sale pm for details
Turbo42's Avatar
H&R all the way. I have them on mine. No they did not lower the same. The Eibachs only lower 0.8 all the way around and you still have huge gaps in the wheel wells. Also, they are a much harsher ride. The H&R's give you a great ride and they lower it to about an inch off of the rear tires, looks very good. No need to put the front springs in with the H&R's b/c the gaps in the wheel wells will be the exact same, with just the rear lowered and it will look excellent. Also, it will level the car out if you measure from the ground to the top of the wheel housing on both front and back it will be about a 1/4 of an inch difference. This is why you dont lower the front with the H&R's it would then make the front lower than the rear rather than equaling it out. So get the H&R's and do just the rear you will be very happy. I have a post on here just search my threads and it will show you my car lowered with the H&R's. The guy I bought them through is a great business guy his name is Darren and he works for www.wsiaz.com Give him a call
Old 10-14-2008, 10:43 AM   #3 (permalink)
stefano2412's Avatar
hello,
i was thinking about H&R springs for my car too, my intent is to get it lower, stiffen the handling a little bit AND reduce the amount of 'ducking' during gear shifting.
since you have done it already, please confirm: if you replace just the rear springs, does the car handle much differently? does it still 'dive' when you shift?
thank you!
stefano2412 is offline   Reply With Quote
Old 10-14-2008, 10:53 AM   #4 (permalink)
Turbo42's Avatar
Originally Posted by stefano2412 View Post
hello,
thank you!
The handling is improved a lot corners are alot better you dont feel like the car is going to tip over. Also the shiftin is fine its no where near what it was like b4 IF you want low and a nice ride go with H&R. If you want a medium drop and a harsh ride go with eibach
Old 10-14-2008, 11:14 AM   #5 (permalink)
Smartmadness.com
2micro4u's Avatar
Sounds good I definatly want a lower drop.
Old 10-14-2008, 11:49 AM   #6 (permalink)
tbone28's Avatar
If the front H&R springs are installed, how much of a gap is there in the front fender?
Old 10-14-2008, 11:58 AM   #7 (permalink)
If you want a stiffer ride than factory springs, the Eibachs are superb. I don't see a need to turn my Smart into a low-rider so lowering was not my main goal. I'm used to a sports suspension and hated the sloshing of the factory springs. I was originally going to skip the springs offered through my dealer until I rode the Smart for a while, dealing with some real motion-sickness for the first hour's worth of driving and hating the "lights up" "lights down" whenever I'd shift gears. The new springs are much better for my tastes. They're as "harsh" as my premium Z4's suspension. What's "harsh" anyway?
Not many here have tried both Eibachs and H&R springs so comparative values will be mostly based one here-say and not on direct experience.
Old 10-14-2008, 03:59 PM   #8 (permalink)
Turbo42's Avatar
not true I have rode in one with Eibachs thats why I choose H&R. The ride was much better witht the H&R springs. Also it does not make it a low rider the smart sits really high off the ground to begin with. The H&Rs make it look very nive no where near a low rider though. I have had nothing but compliments on them so far
Old 10-15-2008, 09:29 AM   #9 (permalink)
mendo's Avatar
I have the Eibachs, I like them.
It did not lower too much, about an inch in the front, a bit more in the back.
I drive over some pretty rough roads through the constant construction on I-80, I noticed that on some bumps that used to bottom out the car, the new springs resist hitting the snubbers just a tad more. that is good.
One of my friends has the H&R and he bottoms out.
I don't detect much difference in the ride of either, they both are much better than the stock.
I don't think the ride is harsh.
Old 10-15-2008, 11:21 AM   #10 (permalink)
I would think a recommendation is better evaluated if I had tried both brands on the car. I went with Eibach cos of a good deal. Installed it and driving on them ever since. I really can't compare to H&R. Only comparison is to stock springs.
Installed H&R springs Turbo42 Interior & Exterior 38 12-16-2008 08:17 AM
EURO-SPEC Eibach springs vs. US-market Eibach springs tbone28 smart Modifications 7 10-12-2008 02:33 AM
New Springs = the way it should be! mendo smart Modifications 36 10-07-2008 10:53 PM
Shatley Springs michaelhammer Carolinas Chapter 3 08-23-2008 12:38 PM
lowering springs pickledchang smart Modifications 89 08-21-2008 04:02 PM
