I was very happy to see that Cisco over at SmartCarPerformance had done dyno testing on a stock smart to provide a baseline for subsequent testing of equipment and software changes intended to enhance hp/torque. Thanks Cisco! After looking at Cisco’s graphs I was interested in how little the hardware improvements helped, though not terribly surprised as most of the aftermarket claims for hp boosts are at best "overly enthusiastic". I have, on my own smart, invested in exhaust, intake air flow improvements and an ECU upgrade with the hope of getting a bit more performance so, with the "stock" smart dyno information now available, I set out to have my own smart dyno tested.
My vehicle was put on the dyno at the same facility that was used by Cisco, that being Brothers Performance in Corona, CA and the runs were conducted by the same dyno technician, John (a nice guy to work with and very helpful). This should hopefully eliminate the test facility and equipment as a variable.
The first run was made in 3rd gear only as that is where maximum hp is developed, the second run was 4th gear only, the third run was a curiosity run in 5th gear only, and the 4th and last run was 1st thru 5th gears. Runs 1, 2 and 3 are all plotted vs. RPM while Run 4 is plotted vs. MPH. I have annotated all of the graphs to make them easier to understand.
http://www.smartcarofamerica.com/gal...?imageid=10070
http://www.smartcarofamerica.com/gal...?imageid=10071
http://www.smartcarofamerica.com/gal...?imageid=10072
http://www.smartcarofamerica.com/gal...?imageid=10073
Some random comments:
1. My test results compare closely with those obtained on Cisco's modified vehicle, that being a gain of slightly more than 4 HP over Jeremy's stock smart. I believe Cisco’s gain was closer to 5 HP.
2. Looking at the 3rd, 4th and 5th gear plots show that the smart has a pretty flat torque curve up to about 5500-5800 RPM and that horsepower peaks lie mostly around 5600-5800 RPM.
3. The differential in HP between gears 2 thru 5, as shown on Run 4, are relatively small varying from 66.5 HP to 69.5 HP. The lower HP for 1st gear shown on Run 4 is, I believe, due to a short upshift in that gear.
4. When I got the Veloce ECU upgrade I had never been able to find out whether the 90-92 MPH limiter function for the stock ECU had been eliminated. I don’t have roads in my driving area that would allow me to find out by actual road experience. Apparently the limiter was removed as the smart reached 97 MPH in 4th gear and 130 MPH in 5th! Keep in mind that actual road speed would be considerably less in that our "flying brick" aerodynamics would obviously slow things down a significant amount
5. I believe that the biggest HP upgrade for the smart is the turbocharged route. With reported dyno tests showing around 110-115 HP for vehicles running 6-8 lbs boost, this certainly beats all of the other bolt-ons for HP gain. As a very rough calculation, if it costs $5000 to get 50 HP (turbo, installed), you would be paying around $100 for each HP. When I added up my expenditures for ECU upgrade, exhaust system, air filter and intake hose it comes to about $1300...for 4 HP! That's $325 for each HP gained
6. An ECU upgrade is probably your next best buy for HP gain, but don't get too attached to inflated advertising gains. An ECU upgrade can provide a pleasurable change in drivability and it did with my Veloce upgrade. Everything isn't about HP
7. A small investment in a large quantity of salt is probably advisable when reading claims for power boosting hardware/software. The emotional boost is likely to far exceed reality. Will I listen to my own advice...probably not
