Originally Posted by buellwinkle
SmartCarPeformance, maybe you can help me understand the graphs. I'm assuming from past experience that you ignore dyno noise and the shift points as invalid data. So the question is, at what point on the bottom graph do you see 76HP, am I missing something? I see the same 70HP peak in the 2 graphs with the ECU mods.
Since it's highly likely the dyno saved these numbers, can you asked him to merge the 3 runs into one graph and do it by RPM so we can we can see the typical HP/Torque crossover at 5252 rpm and see the benefits across the rev range.
Thanks
The graph result we posted were given to us by our local Corona company who has been doing Dyno graphs for many years. We double checked the horsepower that he gave us and he verified it to us and said it was correct.
We had asked him to convert the data to show the horsepower according to the RPM readout but he said because of the current configuration the readings would not have been so accurate. As I said before, it seems that there are several different ways to interpret the graphs. The Dyno is a very static environment which does not take into consideration many factors. It think our Dyno graphs should be used as a guide to help people decide if it is worth it or not. There are also other factors to consider like being able to go faster than 90MPH, smoother shifting, and the overall efficiency of the engine after being remapped.
We are still contemplating taking our Smarts to the track to see what difference this will make. Again, that's not a perfect thing either. You have take into consideration the driver's response time, getting the correct timing, and of course the weather. But it is still in our agenda.
I will have to say the people who have had their ECU remapped have been more than pleased.
