Engine cover fastener screw thing... - Page 4 - Smart Car of America Forums : Smart Car Forum
Trailer
Old 06-15-2009, 11:55 PM   #31 (permalink)
Dan500's Avatar
Sorry Guy. I should have mentioned it was at SCP-Parts. Glad you found it!
Dan500 is offline   Reply With Quote
Old 06-16-2009, 12:27 AM   #32 (permalink)
Dan: did you recieve your new fastener yet? if so, how do you like it?
Old 06-16-2009, 09:22 PM   #33 (permalink)
Dan500's Avatar
Hey Guy, I haven`t received it yet since the "nut" part is on backorder. They`ll ship it all at once since I have other stuff ordered also. Will post when I get it.
Old 07-04-2009, 09:37 PM   #34 (permalink)
I checked out a 2009 smart at smart center Riverside: same engine compartment fastener as the 2008...lame!
Old 07-05-2009, 07:26 AM   #35 (permalink)
lebikerboy's Avatar
The one with the D ring metal top is from a 450...
Old 07-05-2009, 08:54 AM   #36 (permalink)
When I finally got sick of the stock fastener never closing correctly, I pulled out the whole assembly and replaced it with an extruded U-nut and a plain old 1/4" bolt with a washer. 11mm socket works on the hex head.
bluedeuce is offline   Reply With Quote
Old 07-05-2009, 08:57 AM   #37 (permalink)
Mine works fine, you just have to make sure that the cover is aligned properly. Do not lift the cover by the bail nut.
Old 07-05-2009, 09:52 AM   #38 (permalink)
jefferios's Avatar
Any updates Dan?
Old 07-05-2009, 10:46 AM   #39 (permalink)
Photos? DIY tips? Sounds like a swap worth doing.
Old 07-05-2009, 02:06 PM   #40 (permalink)
JOIN SCOA.YOU'LL BE GLAD
...IMHO..check the receptacle first..it gets pushed apart by the locking stud thus making it harder to engage the "screw"..
..the fix is to pull the receptacle out..close it with pliers and re-install...
this guy...
jetfuel...
See thru engine cover. cubefx smart Modifications 48 06-12-2011 09:27 PM
reset check-engine lite...a DIY thing? shop hermit smart Operation and Maintenance 20 10-19-2010 10:56 PM
Screw that holds down the gear shifter cover. Help! Planedriver smart Operation and Maintenance 10 03-18-2010 10:17 PM
engine cover muleguy smart Operation and Maintenance 19 07-14-2008 01:33 PM
I guess I have a thing for rear/mid-engine 2 seat cars! Cory1000 The Car Lounge 12 04-03-2008 11:39 AM
