Engine cover fastener screw thing... - Page 5 - Smart Car of America Forums : Smart Car Forum
Trailer
Old 07-05-2009, 03:32 PM   #41 (permalink)
Dan500's Avatar
Originally Posted by jefferios View Post
Any updates Dan?
Hey Guys, Sorry to not update on here but I`ve been waiting for the "nut" part pictured above. I haven checked my P.O box in about a week so it might be here. The "bolt" is MUCH better than the OEM one.
Dan500 is offline   Reply With Quote
Old 07-05-2009, 04:05 PM   #42 (permalink)
Drive: Pulse
Originally Posted by theguywiththelongestname View Post
The Unifast FASTturn (above) is sort of like what's used in the smart. Ours has a diffent butterfly top piece.
the "bail top" (above, bottom right) Dzus looks like it might be a better fastening solution.
That "bail top" is what we have on the 2004-2006 smarts!
Old 07-05-2009, 07:05 PM   #43 (permalink)
Photos? DIY tips? Sounds like a swap worth doing.
Scarcely seems worth the trouble of a DYI writeup. Pull the stock clip off of the car and slide the U-nut in its place with the threaded piece facing down. Pull the little black washer/retainer off the twist piece in the hatch cover and remove the twist piece. Put the hatch cover back in place, then insert the bolt and washer through the hole and turn the bolt by hand to engage the threads on the U-nut. Tighten down snug, but don't go to town on it. Throw the three stock pieces in the trash where they belong.
U-nut (the part sticking up will be facing down when you slide the clip on):
bluedeuce is offline   Reply With Quote
Old 07-05-2009, 07:33 PM   #44 (permalink)
Yep. Mine's been working fine for about 14 months now. The Dzus set up is a good quick-release for motorcycle fairings--clearly not the best fastener for Smart's engine lid.
EdwardDennis is offline   Reply With Quote
Old 09-14-2009, 08:21 PM   #45 (permalink)
I finally figured out it was my technique that was causing the problem. fastening the cover is a two-handed job.
1. replace cover and make sure it is lined up properly re: rear tabs and square with compartment...line up fastener with nut etc...
2. push down on cover (near fastener) with one hand
3. while still pushing down on cover, easily turn Unifast fastener with other hand...it turns smoothly into closed/locked position
if you are expecting to fasten-down the compartment panel with one hand, forget it...the panel needs to be compressed into position before fastener functions properly (think aircraft panel).
Old 11-30-2011, 10:59 AM   #46 (permalink)
clip
I have lost the clip somehow probably broke anyone know where to get a replacement?
scirocco16v is offline   Reply With Quote
Old 11-30-2011, 11:04 AM   #47 (permalink)
wrumbarger's Avatar
Old 11-30-2011, 06:19 PM   #48 (permalink)
Been smart for 3.59 years
NCC1701's Avatar
My nephew accidentally broke mine on Thanksgiving day. Well, it has been a week and I kinda-sorta actually forgot about it until I saw this zombie bubble up. Just wondering how important replacement is. I mean, the cover snaps into place and is held down by the carpet cover. Doesn't seem like it's going anywhere unless by intent. Whatever OCD I have hasn't been activated by the broken clip.
Old 11-30-2011, 11:38 PM   #49 (permalink)
If you are driving with a tail wind, it blows hot air into the car past the cover.
I gave up trying to find the fastener (here it comes) since we don't have a local dealer... and went down to Ace Hardware, picked up a j-nut and thumbscrew. I pulled the old clip off, put the new one in place and I can now tighten the cover down with no problem. I added a clip on the thumbscrew to keep it from falling out when the cover is off. Total cost was about $2 and 15 min of time to install.
See thru engine cover. cubefx smart Modifications 48 06-12-2011 09:27 PM
reset check-engine lite...a DIY thing? shop hermit smart Operation and Maintenance 20 10-19-2010 10:56 PM
Screw that holds down the gear shifter cover. Help! Planedriver smart Operation and Maintenance 10 03-18-2010 10:17 PM
engine cover muleguy smart Operation and Maintenance 19 07-14-2008 01:33 PM
I guess I have a thing for rear/mid-engine 2 seat cars! Cory1000 The Car Lounge 12 04-03-2008 11:39 AM
