Engine paint as Caliper Paint - Smart Car of America Forums : Smart Car Forum
Old 06-17-2009, 03:49 PM   #1 (permalink)
Dont Feed The Trolls ^Mod
jediknight36's Avatar
Myself and a fellow smart owner painted my calipers last weekend. The paint I got was blue caliper paint and it was the only blue caliper paint I could find. It turned out it was a royal or darker blue than I wanted. I have found pictures online of electric and metalic blue calipers but cant find that color blue caliper paint, even online, w/o spending $0-$60 bucks. I did find engine paint that does have a high heat resistance. The caliper paint says up to 900 degrees while the engine paint is good to 500 degrees.
I have seen some comments on the net sugestion using the engine paint and it works fine, but not knowing the size of the wheels I am not sure.
Would using the engine paint on my break calipers and roters be ok?
Old 06-17-2009, 03:54 PM   #2 (permalink)
You don't want to spend $0-$60?
VHT Bright Blue Caliper Paint available under $10 many places online.
Old 06-17-2009, 03:56 PM   #3 (permalink)
JOIN SCOA.YOU'LL BE GLAD
..jedi..just paint the darn things and post pics....my 65 calipers were painted using plain Jane rustoleum paint...brushed on... not sprayed on and still look damn good..
jetfuel....my 1c
Old 06-17-2009, 05:11 PM   #4 (permalink)
Im on my phone and the 4 in $40 didnt make it. I used the bright blue and it turned out dark. Guess Ill use the engine metalic blue
Old 06-17-2009, 06:19 PM   #5 (permalink)
donnyonee's Avatar
i also used the plain jane rustoleum brushed and had no problems
Old 06-17-2009, 07:55 PM   #6 (permalink)
Owner for 3.8 years
Kermit's Avatar
Just paint it already, if your calipers get up to 500 degrees your car is most likely already on fire.
G2 Yellow Caliper Paint and Black Drums tigerwong58 smart Modifications 12 01-01-2010 07:20 PM
Paint protection BAGTGG smart General Discussion 12 01-30-2009 06:18 PM
Yellow paint ?? smartfx smart General Discussion 4 12-11-2008 06:37 PM
one-of-a-kind paint job? JetJazz Texas Chapter 28 09-06-2008 12:18 PM
Paint code to match paint to white plastic GiantKiller smart Modifications 20 05-10-2008 09:43 PM
