Originally Posted by TMACK
The resonator box incorporates the function of the hose; it is an integrated unit.
And it is a trip to get out in one piece.
I believe a prior post was accurate: dropping the engine by two inches would probably allow enough room to extract without going the wheel well route, but I wasn't about to do that as a backyard mechanic.
Indeed. I've been trying to incorporate an exterior-mounted Baron's air kit.
The cosmetics application is obviously challenging-- (... I discounted a simple wheel-well opening)---let alone the intake tubing support.
It's unfortunate that the driver-side quarter-panel plastic is manufacturer-recessed to accomodate the stock plastic grid. Availability of a smooth-sided panel would permit a little low-cost experimentation. I'm thinking of searching for some cheap quarter-panels to experiment on.
MHLO, of course...
