Fuse 11 jumper - Smart Car of America Forums : Smart Car Forum
Old 06-25-2009, 07:52 PM   #1 (permalink)
SmartDigger's Avatar
Fuse 11 jumper
I remember seeing a post about making a fuse switch using a fuse buddy. I can not find it though. can anyone help me out in finding this? thanks
Old 06-25-2009, 09:23 PM   #2 (permalink)
Old 06-26-2009, 04:16 PM   #3 (permalink)
No, It was a fuse buddy wired to a toggle switch so the circuit can be switched off but still be fused.
Old 06-26-2009, 04:30 PM   #4 (permalink)
JOIN SCOA.YOU'LL BE GLAD
...is this it?...
Controlling the ESC?
jetfuel
Old 06-26-2009, 05:03 PM   #5 (permalink)
Drive: Pulse
Originally Posted by jetfuel View Post
...is this it?...
jetfuel
You have to turn the car off to either engage or disengage the ESP. Can't do it "on the fly."
Old 06-26-2009, 05:14 PM   #6 (permalink)
jetfuel
Old 06-26-2009, 08:40 PM   #7 (permalink)
Yep. Made one to night. I got the multi tester and soder out and had at it. Even though it was very hot to day, I thought I better make it or else there would be snow flying and I would be saying....I wish I would have made that switch.
I like this type since it would be hard for someone to switch it on the fly. Being under the dash and all.
Old 06-27-2009, 09:21 AM   #8 (permalink)
Happy 2012!
I've pulled the fuse and put it back in while the car was running... No issues.
Old 07-03-2009, 10:04 AM   #9 (permalink)
SylenThunder's Avatar
The point isn't that it sometimes works okay. The reason we say not to do it with the car running is because an unwanted surge of power when you flip that switch could destroy your ECM and render your car useless. Sure you can do it, and 90% of the time it will work fine. But every time you flip the switch with the system powered up, you run the risk. It's entirely your choice about taking the gamble. Just remember, it's Russian roulette you are playing with your ECM and not poker.
~Sy
Old 07-03-2009, 10:14 AM   #10 (permalink)
I see this as 100% conjecture. Who is "we" and is there any actual empirical evidence or design knowledge to suggest this is the case? For instance, turning on a lamp when the wall switch is on is no different than turning the lamp on before the wall switch.
Better safe than sorry, sure. But it's conjecture unless "we" knows something more.
Jumper Cables cubefx smart Operation and Maintenance 4 06-02-2009 07:51 AM
Fuse box adapter jwight Audio & Video 8 09-16-2008 08:53 PM
Fuse box on 451 dbatch1715 Interior & Exterior 3 06-10-2008 06:45 AM
Horn Fuse (amps)? brian r smart Operation and Maintenance 3 03-10-2008 11:40 AM
