Hayabusa powered Smart Car (SmartBusa) - Page 13 - Smart Car of America Forums : Smart Car Forum
Old 06-23-2009, 08:45 AM   #121 (permalink)
I agree with Brabus on wondering what the value of OEM parts taken off the smart would be worth. I saw an engine/transmission fuel tank on ebay yesterday for $1500. The guy is doing an electric conversion.
Problem is that not many people will need some of the items pulled from a conversion. I can't remember the last time I needed to replace my brake pedal.
It is an interesting question of the value of used smart parts.
Andy
Andrewlcox is offline   Reply With Quote
Old 06-24-2009, 10:55 PM   #122 (permalink)
LittoDeviL's Avatar
Andy,
Really? Do you still have the link to that ebay or know if it's still going on? Haha I might need an engine or transmission once I blow mines up due to pushing the turbocharger to the limit lol...
Boeschbuilt, keep up the great work! Love the process! Take more pics.. more pics!!! What are you planning to do with the stock engine and tranny?
Cheers!
Larry
LittoDeviL is offline   Reply With Quote
Old 06-25-2009, 08:51 AM   #123 (permalink)
The engine auction is over but here is the link Mitsubishi (Smart Car) Engine 1.0 L, 3 cyl. :eBay Motors (item 230349339019 end time Jun-24-09 20:47:38 PDT).
I am more interested in the guy's electric conversion than the used engine.
Andy
Old 06-25-2009, 07:27 PM   #124 (permalink)
Boeschbuilt's Avatar
The stock engine and tranny thing is another story all together. Right now I don't think they are hardly worth anything because practically everyone is still under warranty. Give it a year or two to let the demand go up. If you are willing to list all the items separately (engine, trans, starter, alternator, etc. etc) and I think you might be sitting on a small fortune, enough to pay for a sizable part of the kit. I don't know what the owner of the car is going to do with this engine, we will have to see when the car is done.
Boeschbuilt is offline   Reply With Quote
Old 06-25-2009, 08:30 PM   #125 (permalink)
Ahh, the sweet smell of progress is in the air. Been putting major hours into the project, here is an update!
Got the gauges in. It is made from a company in Canada called KOSO.
It is really cool looking, it has everything in one spot, speedo, tach, turn signals, temperature readings, even things like high beam indicators and a check engine light.
Finished up the header and the oil cooler lines.
Those little arms that I had holding the rear suspension straight didn't work. When the suspension would go up and down through the travel it would bind up. This was happening because those bars were traveling on a tight arc where they would need to move both in and out quite a bit. The solution is the long bars on the bottom of the picture, they will pivot from the middle of the car just like from the factory. I also decided to use Polyurethane bushings instead of heim joints. Heim joints tend to squeak really bad on the street.
This the stock Smart Car fuel tank and fuel pump assembly. I am going to run an external Aeromotive Pressure regulator with a fuel return that will go back into this tank. The bike runs on 44 psi and I am almost positive the Smart pump puts out at least 60PSI.
I had decided to just go ahead and send the wire harness out to get modified. I called a couple companies that do this sort of thing and decided that I could do it just as good if not better. I have started cutting out excess wires, tricking sensors with resistors and such, hooking up the gauge harness and adapting it all to the smart with nice weatherpack plugs and everything. here is the work in progress.
This is my helper, she really likes Smartbusa's
Also, lots of things are sent out and getting worked on as we speak.
Mark Williams Enterprises are making chromoly axles.
Hel brake lines are making a braided clutch line.
And Barnett is making a custom throttle cable.
Only the best parts for Smartbusa!
Old 06-25-2009, 08:38 PM   #126 (permalink)
JOIN SCOA.YOU'LL BE GLAD
...keep on rocking dude...
...what's the helper's name?
jetfuel
Old 06-25-2009, 11:55 PM   #127 (permalink)
LittoDeviL's Avatar
When I read this I thought this was coming from someone else, were u talking in third person view? hehe..Didn't understand what you meant if we were willing to list all the items separately? You mean if we told you that if you were willing to list the items separately then you would be able to sell it and make a small fortune in the future?
And.. hah I was asking about your engine because i'm like.. 1000 miles away from my 24,000 warranty and if I blow up my engine it would be nice to buy it from someone like you that still has a working engine?
Great pics by the way!! I know Mark Williams Enterprise, they made me my custom designed forged axles for my DeTomaso Pantera, check it out
LittoDevil's Custom Brake, Hubs & Wheels
P.S. If you need a source for.. whatever you need in the future of this project and can't find a source or need a recommondation, let me know
Keep up the great work!
Larry
Old 06-26-2009, 06:17 AM   #128 (permalink)
Drive: Pulse
Looking good fella :-) There are quite a few things I've bypassed on my gsxr1000 wiring.. just a little check list for you..
Clutch lever sensor (short)
Tilt sensor (short with 66k resistor)
Stand sensor (short)
Exhaust value (remove pin 33 from ecu plug)
Remove bike Ignition (short + add 100 ohm resister)
Run switch (short)
Wires I've had to cut and chop into my smart are.. Grey wire (gsxr wiring) going to clocks.. Dial Lighting when car lights go on (tapped into rear light for this) Two wires in the smart key.. one going to starter motor other ignition on all the time (orange ?)
I also wired up the petrol pump wire from the gsxr to the smart pump.. red wire from under.. hmm drivers seat ? (my passanger).
think thats about it m8
Sent you a pm re - fuel return :-)
cant wait to see this ..
Steve
CdRsKuLL is offline   Reply With Quote
Old 06-26-2009, 08:35 AM   #129 (permalink)
try this link for a dragracing calculator
Ray Hall Turbocharging - Java drag racing calculator
1500 lbs at 180 bhp = 11.8sec qtr mile time
knick is offline   Reply With Quote
Old 06-27-2009, 10:31 AM   #130 (permalink)
Larry
Hey litto devil. I wasn't referring to my self in the third person- when I said owner of the car, I mean that I don't actually own this car, I am building it for someone else, (Knick on the forums). Also, about selling the parts, If I ship a kit to someone out in California and they have the ambition to sell all of their stock parts separately on Ebay then they would make a whole bunch of money to help pay for their Smartbusa kit.
P.S. those axles turned out very nice!
Run switch (short)
Steve
Hey Steve, thanks for all of the help, It sounds like we both ought to be up and running about the same time!
Good deal, This thing is going to surprise some people on Woodward Ave.
Oh yeah, almost forgot, Jetfuel, The helpers name is Dakota
smartbusa smartuki
Smart Hayabusa conversion.... yoshi smart Modifications 134 03-22-2011 12:26 PM
hayabusa swap pmikucki91 smart News & Rumors 3 07-01-2009 05:53 PM
How can I get a smart car with a Hayabusa engine? mnext02 smart Modifications 16 02-15-2009 11:33 PM
Jet Powered Smart Fortwo? BigWarpGuy The Car Lounge 11 07-31-2008 11:25 AM
Smart Car Li ion powered Hybrid jonnysan The Car Lounge 2 10-08-2007 05:39 PM
