HELP ME: Request for tech information: (Re: temperature gauge) - Smart Car of America Forums : Smart Car Forum
Old 01-28-2009, 03:55 PM   #1 (permalink)
My smart center said they could install a temperature gauge for me. So, I bought an Auto Meter Ultra-Lite II (#4937), electric, short sweep, with a pedestal mount (#49008). Then, I spent a whole morning at the dealer and the job didn't get done. Apparently, I need a T-shaped temperature sending unit connector--the male side screws into the block and the two female ends on the T are plugged with the sending units (I guess) wherein a wire off of one goes to the gauge, and the wire off of the other goes to the warning light on the dash. They said that was the only way it would work. Fine, but the dealer couldn't tell me what size threads I needed on the new T-connector for the block side, because they didn't have the info in their parts data base. One option was to leave the car there, remove the temperature sending unit, and take the sending unit with me from place to place to match the metric threads to a T-connector--not a good option, I need my car. The other option was to buy a sending unit and take it with me so I could use it to match up threads with a T-connector. But they didn't have one in stock, and I wasn't sure I wanted to spend $120 for one, anyway. So, I went to the auto parts store, and they couldn't find any information in their data base, either. I went to a Mitsubishi dealer parts dept. (since Mitsubishi makes the smart's engine), and they couldn't find any info either (he said probably only the manufacturer of the car would have the info). So, here I am, I spent $100 on the gauge and the mount, and can go no further until someone tells me what size T-connector I need to buy (and where to buy it). My terminology or nomenclature above might not be correct, but I hope you'll understand what I am talking about. Again, the Smart Service Center doesn't have the info. HELP ! (Shellcaptain@sbcglobal.net)
Shellcaptain is offline   Reply With Quote
Old 01-28-2009, 04:00 PM   #2 (permalink)
Still trying to understand your paragraph there...
So when you tagged this as "engine temp", you referring to the oil temp or coolant temp?
I have a gauge that monitors both engine oil temp and coolant temp. So I have experiences what parts to get or modify etc.
Old 01-28-2009, 04:18 PM   #3 (permalink)
brian r's Avatar
I'm guessing coolant temp, since the dealer told him that one lead had to go to the warning light on the dash cluster. I doubt there's an unused oil temp warning light in there.
This shouldn't be difficult to get up and running.
Old 01-28-2009, 04:23 PM   #4 (permalink)
SmartTech's Avatar
did you ever get the threads measured for pitch and diameter (ie 12x1.5) or is it metric pipe thread?
Old 01-28-2009, 04:40 PM   #5 (permalink)
cubefx's Avatar
Auto Meter Ultra-Lite II (#4937) is electric water temperature gauge. For that price and hassle, it is MUCH easier to buy ScanGauge II and it will show you water temperature and much more right out of the box in 10 seconds.
CUBE
Old 01-28-2009, 04:46 PM   #6 (permalink)
JOIN SCOA.YOU'LL BE GLAD
CUBE
...ring the bells....we have a winner....well said CUBE...
jetfuel
Old 01-28-2009, 06:13 PM   #7 (permalink)
Senior Smartie
jonnysan's Avatar
NO such thing.....
As metric pipe thread, Smarttech. Metric straight thread such as what's found on bolts is as you have illustrated above. Another popular Japanese pipe thread is ISO. BSPT (British Standard Pipe Tapered) is another and BSP (British Straight Pipe) is usually used with a face seal o-ring. If it is ISO, the fitting will have an "RT" stamped on the hex of the fitting.
Some standardization, huh?
Old 02-01-2009, 06:22 PM   #8 (permalink)
pitstopautoinc's Avatar
shellcaptain i have all autometer gauges in my smart... their tach, their shift light, their digital controller, their oil pressure, and their water temp. maybe my threads can help you:
Adding Autometer Gauges to your Smart Fortwo
http://www.smartcarofamerica.com/for...earchid=655883
Old 02-05-2009, 01:17 AM   #9 (permalink)
lol! I read his lines too fast...
I replied his PM. Never heard back. Hope he got his parts all sorted out.
Old 02-09-2009, 04:10 PM   #10 (permalink)
Temp guage
Smartieparts has a "Scan Guage" that hooks into the computer, gives u water temp + lots more information
brockins is offline   Reply With Quote
engine temp sending unit, temp gauge
Tech/Tech Assistance Regarding Inop CD Player Big Panda The Car Lounge 1 11-17-2008 10:08 PM
stuck temperature gauge ms bea smart Operation and Maintenance 6 07-15-2008 04:14 PM
Hit 90 today and I don't mean the temperature curtis smart General Discussion 8 06-12-2008 05:25 PM
Pic request. TOOL GD3 smart Gallery 7 12-10-2007 05:33 AM
