Originally Posted by Smart09
you completely took off your sway bar and didnt put it back on??? any problems faced with doing that?
i took my car to JR electronics here in miami to install the front springs and they ended up not doing it but now my sway bar is loose on the driver side. i tried tightening it but its as tight as it gets and its still loose.. should i just take it off?
With the springs I have put on, the bar is unnecessary.
With stock springs, you should keep it on.
The "bolt" part of the sway bar link has a torx fitting on the end.
You will need a tool to hold the stem while you tighten the nut.
Find the right tool by sizing it to the one on the strut end of the link as it is easier to see.
