Like it says,
How to replace a rear spring.
http://www.randyzimmer.com/smart/spr...earspring.mpeg
Give me a break, I decided to do it on the way home for lunch and was only 5 minutes late getting back.
That was after "editing" too.
Could be better and I probably will cut some dead air out but...
I was in a hurry!
If you have stock springs, put a jack under the swing arm before you take out the shock bolt.
On the left side, don't go further down than you must as the axle gets really stressed on that side.
