A friend was kind enough to help me add wings to IKE. Install was actually easy and straigh-forward.... although I was very nervous going into this level of modification.
I altered the instructions a little bit reguarding the L bracket. there is a factory stud nearby that holds the factory L bracket. Its a bit too close to the vertical hinge but if you grind about 1/8inch off the top of the bracket, it fits with the factory stud/nut without interfering with the new hinge.
I had some reservations about buying this, as SmartMadness can confirm. LOL They were kind enough to answer many questions and even send detailed pis of their own car to help me understand what the install would involve and how it would look in the end.
Not much more to tell, so on to the pictures!
IKE without his face!
This is the hinge
IKE has no door!
Hinge installed, door closed
Higne installed, door up
Finished look from the rear
Finshed look form the side
Finished look from the front
