Installation of 2" Hitch & Bike rack Pictures - Smart Car of America Forums : Smart Car Forum
LinkBack (4) Thread Tools Display Modes
Old 02-11-2008, 07:30 PM   4 links from elsewhere to this Post. Click to view. #1 (permalink)
Here are 8 pictures of the construction and installation of a 2 inch Receiver on our 2008 smart cab.
The fabrication and installation took about 3 hours in my home garage.
1. First step is to remove rear lower splash shield. There are 2 bolts and two plastic retainers. After removing the fasteners pull the bottom of the splash shield rearward and it will snap out.
2. The next step is to remove the 6 Torqx bolts holding the rear cross member and then remove the cross member. The cross member is the formed steel bumper that performs the function of a bumper, Exhaust shield and houses the threaded spuds for the tow hooks. The cross member is very light weight and easy for a single person to manage.
3. The next step is to box the cross member in to increase its strength. I used 4 3/4 wide .125 thick stainless steel for this task. I TIG-ed the stainless to the high strength steel used to make the cross member.
4. The next step is go to UHaul and buy a 2 inch to 1 1/4 bike rack adapter.
these come Black Powder coated and are easy to trim for installation.
5. The next step is to weld the 2 inch receiver to a 1 3/4 thick wall angle iron piece. The angle iron I used was a 12 inch piece of stainless . All the stainless I used for this project was purchased for $15 at a metals house. The pieces I bought were in the remnant bins.
6. The next step is to drill 4 holes in your angle iron that will match to 4 hole drilled in your "boxed" cross member. If you use stainless for your project go to Home Depo and buy a 3/8 inch cobalt drill bit. Stainless is HARD!
7. Tig the 2 inch receiver and angle iron that you bolted to your Cross member. Finish boxing the completed assembly and Paint with black spray paint or have complete project Powder Painted Black.
8. Reinstall cross member and enjoy the New Utility.
The finished unit will allow a floor jack placed under the 2 inch receiver to lift the entire rear of car. I pulled a 900 pound utility trailer 10 miles over the weekend. I Kept my speed to a max of 45 mph and the car in no more than third gear. I also carried our bikes about 40 miles down the freeway for a century ride on sunday. The bike carrier I use is the SoftRide unit . I plan using the hitch for carier baskets and bike racks mostly. The SoftRide will fold down and allow full access to the rear of the car.
I am new to this forum and I am not allowed to post pictures.
WOULD SOME KIND PERSON ON THIS FORUM PLEASE E-MAIL ME an Email address
SO THAT I MAY SEND PICTURES for THEM TO POST TO THIS THREAD? My Email address is alantravis@cox.net
Thanks,....Alan Travis
AlanTravis is offline   Reply With Quote
Old 02-11-2008, 07:39 PM   #2 (permalink)
SmartPassion's Avatar
How is this going to affect the transmission...
Old 02-11-2008, 07:47 PM   #3 (permalink)
When You pull , you should keep it manual mode. It seems to short shift in auto mode. My main use will be mostly bike hauler and my jet ski and motorcycle puller. I tried the 16 foot Wells Cargo trailer to see what it was like to pull. The smart pulled it fine but it would be a thrilling ride if a panic stop was needed.
Old 02-11-2008, 10:29 PM   #4 (permalink)
Dave777's Avatar
Here are Alan's photos. It looks like a really nice, clean installation. My only question is where have you mounted the lights plug for the trailer?
Perhaps an Admin can move this thread to the Modifications Forum?
Old 02-11-2008, 10:30 PM   #5 (permalink)
Dave777's Avatar
More photos:
Old 02-11-2008, 10:39 PM   #6 (permalink)
Dave777's Avatar
If I understand the photos correctly, your 4 nuts are inside the welded box section? So this is now a permanent mounting and you can't take the bolts off and remove the hitch?
Or am I missing something?
Also, is there a location to attach a safety chain?
Old 02-11-2008, 10:51 PM   #7 (permalink)
Moved to the modification section as requested.
Old 02-11-2008, 11:06 PM   #8 (permalink)
Thanks Dave for posting the pictures. I have not decided on the wiring plug location yet. I have only had the car for 2 days so far.
The nuts for the 4 bolts are in the "boxed in" cross member. I can not remove the 2 inch receiver , as I also welded the angle iron to the cross member. I can, however , simply purchase another cross member and the inexpensive rear splash piece and return the car to stock. It takes less than 15 minutes to R&R the cross member. I welded and bolted the angle for piece of mind. The motorcycle I pull around is a 1918 Harley w/sidecar ,restored.
Old 02-11-2008, 11:38 PM   #9 (permalink)
Dave777's Avatar
Thanks Alan.
Obviously wiring and safety chain location are not an issue if one is just using the hitch as a bike rack.
Old 02-11-2008, 11:53 PM   #10 (permalink)
Dave777's Avatar
Here is a different setup, for a trailer hitch, but without the versatility to use it as a bike rack.
http://www.smartieparts.com/shop/ind...roducts_id=287
towing, trailer
LinkBack to this Thread: http://www.smartcarofamerica.com/forums/f19/installation-2-hitch-bike-rack-pictures-3588/
Bad News and (hopefully) Some Good News re: trailer hitch - smart USA insider This thread Refback 08-26-2008 01:23 PM
Bad News and (hopefully) Some Good News re: trailer hitch - smart USA insider This thread Refback 08-13-2008 06:29 AM
Small Trailer - smart USA insider This thread Refback 07-19-2008 10:35 PM
Small Trailer - smart USA insider This thread Refback 06-19-2008 08:27 AM
Trailer Hitch mginsa smart Towing 52 04-14-2009 11:30 AM
Aftermarket stereo installation tee4 Audio & Video 38 08-16-2008 06:16 PM
Smart Car Bike Rack---- I would have never guessed Rogue Smart smart Gallery 49 05-04-2008 06:22 PM
Trailer Hitch?? Smartfor2guy smart Modifications 10 01-26-2008 08:52 AM
Bike Rack for Smart skyzdlimit59 smart General Discussion 2 01-04-2008 12:08 AM
