Music Game
Old 07-02-2009, 04:51 PM   #1 (permalink)
Smart09's Avatar
Installed breathless V2 but....
Rattling from exhaust. Took out and reinstalled but same problem. It's a faint rattle but I can hear it. Anyone else?
Smart09 is offline   Reply With Quote
Old 07-02-2009, 07:33 PM   #2 (permalink)
chumly's Avatar
Drive: Smart cabrio,Ford Escape
Mine rattles a little when at idle but smoothes out above that,I found one of the bolts came loose ,I tightened it and there is still a slight rattle but I can live with it.
chumly is offline   Reply With Quote
Old 07-02-2009, 08:02 PM   #3 (permalink)
is that the dual center tips....
Black is offline   Reply With Quote
Old 07-02-2009, 08:14 PM   #4 (permalink)
chumly's Avatar
Mine was but I modified it to work with my trailer hitch.I cut it off at the downturn and welded an elbow to it so it exits to the back instead of pointing down.What can I do with the dual outlet? Any suggestions?
Old 07-03-2009, 10:23 AM   #5 (permalink)
Smart09's Avatar
Yes I have the center exit exhaust. But it's like metal grinding metal. Could it be my heat shield?
Old 07-07-2009, 06:14 PM   #6 (permalink)
Supporting Vendor
Drive: Corvette Z06, Smart + More
Do check the heat shield.
__________________
Breathless Performance Products
For Smart Performance
www.BreathlessPerformance.com
954-925-7725
Old 07-11-2009, 12:26 PM   #7 (permalink)
Smart09's Avatar
i looked at the car again and it makes that grinding noise only when my A/C is on. once in a blue moon does it do it with the A/C off. i did everything i was supposed to do right. would removing the heat shield be dangerous?
Old 07-11-2009, 12:46 PM   #8 (permalink)
Supporting Vendor
SmartMadness's Avatar
Drive: Smart & the classic Mini
We used to have the VI, VII and VIII on our smart car and had the same issues.
The noise you are hearing is most likely caused by the exhaust being too close to the heat shield and at times touching. The stock engine mounts give the engine lots of movement and with more and more miles the rubber on the mounts softens up and allows even more movement.
Couple of things you can do...
One is doing some tweaking to the heat shield to give it plenty of clearance. It may look like you have plenty, but once the engine moves the gap narrows. The other thing you can do it take the car to a local muffler shop, tell them the problem and have them heat the exhaust pipe (they should be able to tell where it is touching by the scratches on the pipe) and tweak it a bit along with the shield.
Last thing!!! Important! Make sure the bolts are on tight and periodically check them (we used to check them every 500-1,000 miles) and make sure they are tight. This exhaust has a tendency to have some vibration that may cause the bolts to loosen a bit. A bit of thread locker may help with that or locking washers.
Hope that helps a bit.
__________________
Check out www.SmartMadness.com for the largest selection of smart car Parts and Accessories in stock at the lowest prices.
Old 07-12-2009, 09:34 AM   #9 (permalink)
Smart09's Avatar
thank you.. im going to go ahead and do all you said.. it is quite annoying the rattling and metal scraping.
For Sale: Breathless Performance V2 Exhaust A1 RDL Smart Car Parts Marketplace 5 09-15-2009 11:28 PM
Breathless Performance-1st class all the way kwagar Smart Car General Discussion 5 02-10-2009 09:30 PM
Request to BREATHLESS cubefx Smart Car Modifications 13 08-23-2008 07:07 PM
New DIY Template for Breathless Exhaust cubefx Smart Car Modifications 2 06-29-2008 12:30 PM
Installed my Breathless Sport exhaust ! pepcan Smart Car General Discussion 2 06-19-2008 07:09 PM
