Originally Posted by zenrider112
I installed mine last Sunday. Had the following difficulty: The original plug to the accelerator was too loose to stay plugged in.
The install instructions should tell you to use one of the included
zip-ties to zip the accelerator plug to the circuit board.
There is a hole in the board just above the connector that you can run the zip-tie through. You then slip that up through the wires coming out the back of the black connector plug (originally going to the pedal) and zip it in place. Quick/simple solution, and won't come loose from vibration, since zip ties are designed to tighten if anything with vibration. And if you want to undo it, just clip the zip-tie and you're good.
Originally Posted by Gilbert's
I change the led with brighter one's and push it all the way to the face plate for bright light.
I did this too and found the best spot was about 1cm from the front. Too close, and you get a lopsided brightness for red and green. The LED is not
quite as bright as the rest of the LEDs in the speedometer, but when pushed toward the front it's pretty close, and definitly usable even in direct daylight.
