IPOD dock for Smart - Smart Car of America Forums : Smart Car Forum
Old 10-06-2008, 12:33 PM   #1 (permalink)
IPOD dock for Smart
I was wondering if anyone has some suggestions for integrating a IPOD touch dock into a Smart? I would like to hardwire it to make a cleaner install without visible cables.
Old 05-20-2009, 05:51 PM   #2 (permalink)
Oldbike, Go to Radio Shack,they sell a double ended cord for ipods. plug it into the connector in the left side of the glovebox,run it out of the bottom LEFT corner of the glovebox. Plug it into your ipod set your ipod up along the RIGHT side of the dash. My ipod is partilly covering the #6 radio select button,(I have the older square type), I put a small square of velcro on the dash and on the back of the ippd. If you bend the wire 90 degrees straight up and put the velcro on the top rear of the ipod you should only have about 2" of plug and wire showing . The ipod will look like it si balancing/perched on the wire. Best part is, the connector only costs $6.99. After you have the wire bent and the ipod mounted you can gently push the wire exiting the bottom corner of the glovebox down between fabric of the dash. That will hold the wire in position. Slowly and gently close the door of the glovebox,that will mash the wire slightly between the glovebox door and frame. This wire only connects the ipod through the car's radio to the speakers. It does NOT CHARGE the ipod. I purchased the 120 volt wall charger for the ipod. You also use the ipods touch controls to play /change songs. I like the shuffle feature so I don't have to mess with it while driving. Hope this helps. Cheers, SmartChip
SmartChip is offline   Reply With Quote
Old 05-21-2009, 04:57 AM   #3 (permalink)
Carsten's Avatar
Hi try to see my solution..
Iphone 3G in my Smartcar solution
I does also fit an ipod touch, and the cable in the bottom does provide charge, and aux to the radio.
There are rubber pieces with the package to fit itouch..
Regards
Carsten
Carsten is offline   Reply With Quote
Old 11-30-2009, 03:03 PM   #4 (permalink)
dock
i've just seen you're post.
don't know if you're still looking for something..
but ive fixed it like this:
(need to post 3 for images ,CRAP)
Works SUPER!
greatings from holland!
sebastiaan is offline   Reply With Quote
Old 11-30-2009, 03:04 PM   #5 (permalink)
2
this is post 2
Old 11-30-2009, 03:04 PM   #6 (permalink)
3
and this is post nr 3
Old 11-30-2009, 03:05 PM   #7 (permalink)
dock
Okey here we go again!
Works SUPER!
Old 11-30-2009, 03:26 PM   #8 (permalink)
Well that was worth waiting for your three posts.
Love the look of that and the pracricality. Now where Do I find a dock like that.
Glad you took the time to join us to show off your handy work
Old 11-30-2009, 05:02 PM   #9 (permalink)
Very nicely done, thank you for posting it.
Old 11-30-2009, 05:04 PM   #10 (permalink)
banned
That is bad ass!!!!!
Ipod nano (and other mp3) SiestaSmart Audio & Video 64 08-28-2009 08:06 AM
iPod/iPhone Dock Connector saronian smart fortwo (451 - US vehicle) 19 08-02-2009 01:11 PM
Sittin on the dock of the bay... knelson smart Delivery 5 07-10-2008 05:36 PM
Cars at Baltimore Dock FWOIII smart News & Rumors 3 01-31-2008 08:36 PM
Cars at Baltimore Dock FWOIII smart News & Rumors 4 01-11-2008 08:22 PM
