Old 07-28-2008, 01:23 AM   #11 (permalink)
Napoleon12's Avatar
guide works great. who did the pics and the work i will send u a pint. it will take awhile but it might get there.
Old 08-24-2008, 06:32 PM   #12 (permalink)
tgobie50's Avatar
Thanks
Thanks for the link, building quite a libary.
tgobie50 is offline   Reply With Quote
Old 02-03-2009, 01:37 AM   #13 (permalink)
Drive: Smart/320i/M3
Keep the write-ups coming!!
uberpanzer is offline   Reply With Quote
Old 03-08-2009, 04:07 PM   #14 (permalink)
Brabus's Avatar
Drive: 2009 Smart Brabus Cabrio
It might sound crazy, but I've found a dinner fork works great to remove the pin out of the plastic rivets. It removes them without damaging the rivet whereas when I used real tools the rivet pins were prone to getting damaged.
Old 07-09-2009, 11:35 AM   #15 (permalink)
raytmercer's Avatar
Drive: Passat TDI/Passion (09)
Originally Posted by Frankenstein_Casanova View Post
One small suggestion: The otherwise excellent FQ101 Panel Removal guide suggests leaving the white plastic sill clips on the Tridon and then sliding the sill onto the clips to reinstall them. This is foolish, and will make you old and crazy before your time.
Instead, take the clips off the Tridon and slip them back into their slots in the sills, and then push the whole thing straight back on the car. There are even spiffy little notches in the sill slots to help you get the clips in the correct position to line up with the studs on the Tridon. That crazy "slide the sills back up on the clips" business is just a quick trip to frustration and scratched panels.
Cheers,
Johnny
Thank you ... Thank you. I almost did go crazy, but I thought that the pins had to be screwed into the shell.
raytmercer is offline   Reply With Quote
Old 07-09-2009, 12:19 PM   #16 (permalink)
raytmercer's Avatar
Originally Posted by RussBarnes View Post
I broke one, dealer didn't stock and had to order. Got a pack of 10, good thing cause next time off I broke another. Not real expensive, freight here was more than clips.
Do you have the stock # for the clip?
Old 07-09-2009, 03:03 PM   #17 (permalink)
Clip: A0009912098
Plastic rivet: A00099054929051
Old 08-28-2009, 01:33 AM   #18 (permalink)
wbrian's Avatar
I am sorry to be very dumb when it comes to Smart cars, but is it possible to replace the panels of the Brabus? Also, is it possible to put different colors on each side? Thanks in advance!
wbrian is offline   Reply With Quote
Old 10-19-2009, 09:31 AM   #19 (permalink)
fannum's Avatar
Drive: '08 Cab/09 Pure/'09 Passio
Originally Posted by wbrian View Post
Is it possible to put different colors on each side? Thanks in advance!
Actually, that was the intent of Swatch when the conceived of the car, where you could change panels to suit your mood, outfit or the season!
Cheers, Bob
fannum is offline   Reply With Quote
Door panel removal Westfield 11 Smart Car General Discussion 5 02-20-2009 11:11 PM
Inside Door Panel Removal Agent86 Interior & Exterior 1 04-15-2008 05:25 AM
smart as a rental car - smooth shifting instructions brycenesbitt Smart Car Operation and Maintenance 2 03-20-2008 08:20 PM
