Originally Posted by GHammerly
The smart has a very smooth flat bottom panel, covers at least 75% under the car.
20 % reduction in Cd just lowering the car + front splitter sounds unrealistic.
Sorry, my bad....the source said "20 points", whatever that is. I mistakenly remembered it as percentage. Here's the quote from the above link:
"reading my March 07 copy of Hot Rod I found a report on some windtunnel testing for a slatflats car. it also had some basic tips and tricks of what you can do to your car for improvments, they tested the moon discs and they were good for a 2-4 count reduction in Cd.
Lowering the ride height can be good for up to 20 count reduction and a straight air dam off the front of the car could be good for a 20 count reduction and 50% less lift. If someone wanted they could test some mods on a scale model to check changes in Cd, but you would need a mini wind tunnel"
