New Breathless Exhaust Install (new template) - Page 2 - Smart Car of America Forums : Smart Car Forum
Old 06-26-2008, 07:31 PM   #11 (permalink)
cubefx's Avatar
Originally Posted by Bum-bling-B View Post
Yep, Manila Beige (yellow) '83 240D with a 300D motor swapped in. Nice car but I have stopped driving it since I got the Smart.
Mine was '79 200D, slow but I did have great MPG around 40/45.
CUBE
Old 06-26-2008, 07:47 PM   #12 (permalink)
VERY nice. I like your template better than Breathless' as well. Nicely done my friend!
By any chance, would you be able to post up your template (actual size) so we could make use of it? Maybe even the Breathless one as well? Your help would be greatly appreciated. If not, no worries at all. Thanks. ;)
Old 06-26-2008, 07:54 PM   #13 (permalink)
mendo's Avatar
My exhaust will be here in about a week, it just shipped. I am going to attempt a closer fit, kindof a sideways 8 design.
I will post pics and results as soon as I can.
this one is nice!! I like the roundness!
Old 06-26-2008, 08:30 PM   #14 (permalink)
MSOEMiller's Avatar
Awesome. I had asked in a thread if anyone tried a different cut-out.
V-nice. I will cut mine in just like yours.
MSOEMiller is offline   Reply With Quote
Old 06-26-2008, 08:40 PM   #15 (permalink)
TINSEL's Avatar
"Touring" or "Sport"?
Nice install and trim. Is yours the "Touring" or "Sport" model? Thanks Steve
TINSEL is offline   Reply With Quote
Old 06-26-2008, 08:41 PM   #16 (permalink)
bottlerocket's Avatar
Anyone have a sound clip of the breathless exhausts?
bottlerocket is offline   Reply With Quote
Old 06-26-2008, 08:47 PM   #17 (permalink)
cubefx's Avatar
Steve,
Mine is "sport".
CUBE
Old 06-26-2008, 08:50 PM   #18 (permalink)
cubefx's Avatar
You can find video of sport version "in action" on youtube if you search for "Breathless Performance".
CUBE
Old 06-26-2008, 09:14 PM   #19 (permalink)
I like the cut out also. If you like send it to us and we will make copies and send both with all the systems sent out.
Ernie
Old 05-25-2009, 07:24 PM   #20 (permalink)
Brabus's Avatar
I feel like an idiot. I just spent about 4-5 hours trying to remove the stock exhaust on a Passion Smart. I'm trying to get it off so I can install a Breathless Exhaust. The website states "It is a very easy install". Yes, it would be if I could find a tool to get at those two 12mm star bolts (flange). I have a 3/8" 12mm star socket and I bought all sorts of socket wrench adapters. The problem is the exhaust cover doesn't really give you room. I removed the valence and I'm considering taking off the black painted bumper panels, but I'm still not sure I could access it. I might just run down to Midas and see what they'd charge.
I think a 12mm star wrench would probably be easier, but autozone doesn't have them. I can't put my socket wrench on them unless I use a 90 degree adapter and that seems to not give it enough torque to loosen it. It's a really tight area with about everything possible in your way. Sigh.
Our Products at Breathless Performance
I failed at step 3...the bolt on the flex tube was easy enough but getting at those two exhaust pipe bolts is needlessly ridiculous.
Try to get the car on a lift or at least 2 feet in the air.
1. You should remove your lower valance, just a couple push pins on the ends and a few tabs in the center.
2. Use the template we provide to make and cut the opening.
3. Loosen and remove the 2 flange bolts at the top of the muffler and one on the flex tube.
4. Spray wd 40 on the rubber mounts that hold the muffler in place.
5. Slide the rod of the muffler brace out of the rubber mounts one at a time.
6 Take you stock muffler out.
7 Put our new muffler in place just reverse the procedure. The gasket is re-useable.
Breathless New CES Stealth Drop Down hidden Tip Exhaust System BreathlessPerformance Performance & Handling 25 01-29-2009 07:32 PM
For those asking the question Breathless CES exhaust has NO DRONE BreathlessPerformance smart Modifications 16 07-10-2008 09:01 AM
Installed my Breathless Sport exhaust ! pepcan smart General Discussion 2 06-19-2008 08:09 PM
Breathless Lower Valance for the twin tip or factory exhaust BreathlessPerformance smart Modifications 6 06-14-2008 06:43 AM
