New Springs = the way it should be! - Smart Car of America Forums : Smart Car Forum
Old 09-27-2008, 02:01 AM   #1 (permalink)
mendo's Avatar
I put the new Eibach springs on last week,
I removed the top bolt without removing the cowl by using an allen socket and a wrench.
I removed the bottom strut bolt and left the tie rod, the brake line and the tire pressure sensor hooked up.
I carefully held the strut down and out the fenderwell supported by some wood and compressed the spring and removed it.
replaced it with the new one and repeated it on the other side.
the rear was pretty easy, remove the shock bolts, pry the old spring out, BAM! be careful with this part!! replace with new springs.
the new springs lowered the car about an inch.
The new springs made the car ride like a much larger more solid car.
it doesn't rock when it shifts, it doesn't lean as much when I corner.
it is absolutely what I wanted it to ride like.
I waited a week to see if I had any second thoughts, and no, I still very much like it and will recommend it to anyone.
anyone in N. CA that wants to ride in it to see can hook up with me.
Old 09-27-2008, 05:14 AM   #2 (permalink)
smartHHO's Avatar
Thanks for the info. Sounds like Smart should do the same. Would lower the center of gravity some and if it makes it ride better, might be for the best. Thanks again.
Old 09-27-2008, 07:51 AM   #3 (permalink)
p1nball's Avatar
H&R Springs
Got set of H&R springs today, will mount this week. $230.00 including shipping!! Thanks for the heads up on install!! Wiil take pix's of install.
p1nball
Old 09-27-2008, 08:02 AM   #4 (permalink)
SylenThunder's Avatar
I was working in the garage the other day and came across some cheap 3/4" suspension stiffeners. The kind that you just twist in in-between the spring coils. Was thinking of giving that a whirl to see if it reduced the rocking any. Want a better suspension, but with Michigan winters, I'm not too keen on lowering the car.
Old 09-27-2008, 11:42 AM   #5 (permalink)
GHammerly's Avatar
NASCAR sping rubbers!
Old 09-27-2008, 12:32 PM   #6 (permalink)
Eibach springs with wider front tires definitely improve the handling.
Btw, mendo mentioned that front 22mm (or was it 21mm) nut thing, here's my picture if it helps.
Old 09-27-2008, 10:32 PM   #7 (permalink)
mendo's Avatar
Actually I did not remove the cowl like your pic shows,
I put a 22mm wrench (it is 21mm but I didn't have that one and the 22 worked) on the nut and turned the shock shaft with an allen wrench on a ratchet. you gotta turn the shaft in the tightening direction to loosen the nut because you are holding the nut. it worked good and I didn't have to remove the top cowl.
Old 09-28-2008, 01:39 AM   #8 (permalink)
rwjrn's Avatar
I like the idea of less rocking and less lean in the corners, but am concerned about even worse response to potholes. How do the new springs handle the bumps?
rwjrn is offline   Reply With Quote
Old 09-28-2008, 08:50 AM   #9 (permalink)
mendo's Avatar
There are a couple of spots on I-80 in the construction near Donner that the stock setup hits pretty hard.
The new springs hit the same spots about the same hard.
I didn't notice any additional hammering on any more spots.
I will be going through this area for the next few years as they fix all the bad spots and I am not worried about how it responds now after I put the springs in. I like the way the car feels now, it feels more solid.
It may be that the new springs are stiffer and the larger bumps don't compress them as quickly so it doesn't bottom out as fast.
Old 09-28-2008, 10:48 AM   #10 (permalink)
The really odd bumps will bounce a little more. If you have serious back problems, the springs aren't for you. If you have no extreme orthopedic issues, those rare odd bumps are actually kinda fun!
Installed H&R springs Turbo42 Interior & Exterior 38 12-16-2008 08:17 AM
For sale Eibach springs partsrme928 Archive/obsolete (?) threads 6 09-05-2008 06:43 AM
Shatley Springs michaelhammer Carolinas Chapter 3 08-23-2008 12:38 PM
lowering springs pickledchang smart Modifications 89 08-21-2008 04:02 PM
What brand of Lowering Springs? smartie1 Interior & Exterior 5 05-30-2008 02:41 PM
